Shock tower brackets
Old Dec 25, 2007 | 04:25 PM
fast65's Avatar
fast65
Default Shock tower brackets
I started installing my export brace and monte carlo bar today and ran into a problem putting the shock tower brackets back on. When I try to put the nuts back on the three bolts holding the shock tower bracket on the bolts spin with the nut making it impossible to tighten them. Has anyone else had this problem? How do I fix it?
Old Dec 25, 2007 | 06:59 PM
JamesW's Avatar
JamesW
Default RE: Shock tower brackets
1) hold the bolt end with a vice grip while you tighten. (use a lock washer)
2) raise/lower the car from it's position so the export brace will flex and 'jamb the bolts, holding them while you tighten them.
3) if you haven't attached the firewall portion yet, do so first, then return to these bolts.
Old Dec 25, 2007 | 09:30 PM
fast65's Avatar
fast65
Ok I'll try that. Thanks JamesW
Old Dec 25, 2007 | 09:36 PM
ky's Avatar
ky
America ftw
i pryed a screwdriver under em so they didnt spin. but then i bought the bolts with the square on em so they fit and dont spin. you can get em at osh or dale.
Old Dec 25, 2007 | 10:07 PM
fast65's Avatar
fast65
ORIGINAL: true66gt
I was planning on doing that tommorow. I'll just get some new bolts with the square head and fix the problem once and for all.
Old Dec 25, 2007 | 10:23 PM
4reboy's Avatar
4reboy
yeah just get new carriage bolts, they should have this square head on it anyway
Old Dec 25, 2007 | 10:25 PM
noroof66's Avatar
noroof66
I highly recommend fixing the problem once and for all. If you don't do it now, you will regret when you try to remove them years later.
Old Dec 26, 2007 | 10:37 AM
JamesW's Avatar
JamesW
they are not just carriage bolts. They are actually flat headed speciality bolts. If you're going to use carriage bolts, then grind some flat into thetop, otherwise they will separate the metal layers and the area will sit up slightly.
Old Dec 26, 2007 | 10:56 AM
fast65's Avatar
fast65
Ok, thanks JamesW
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
