Front suspension rebuild
Old Dec 31, 2007 | 12:20 PM
green_blurr's Avatar
green_blurr
Default Front suspension rebuild
I know i need to replace my spring perches the rubber is worn out, do i need to buy a whole kit? or can i jus replace the parts i see that need changing do i really need new controll arms?
any input on someone thats done this?
Old Dec 31, 2007 | 12:28 PM
jlp66stang's Avatar
jlp66stang
Default RE: Front suspension rebuild
If the uppers and lowers are original, all the bushings are probably worn. Mine were! You are going to have it apart anyway. Probably going to need an aligment if you do.
Old Dec 31, 2007 | 12:48 PM
green_blurr
yes everything is original , if i buy a rebuild kit which company should i buy from?
also can i perform this alignment by myself or do i need specail tools?
Old Dec 31, 2007 | 12:53 PM
bluovalguy's Avatar
bluovalguy
Alignment will have to be done at a shop. It should be between $50-100 depending on where you live. As far as which company to buy from, there are tons. Check out mustangs plus, mustangs unilimted, NPD. There are lots more, sure others will chime in soon.
Old Dec 31, 2007 | 01:10 PM
2bav8's Avatar
2bav8
Have you thought about upgrading to roller spring perches?
They cost more, but add so much to a better ride.
I won't own a classic Mustang without a set.
Old Dec 31, 2007 | 01:29 PM
green_blurr
what about poly bushings?
Old Dec 31, 2007 | 01:31 PM
Daze's Avatar
Daze
If you would like to upgrade to roller perches, I have a web page that tells you how to build your own.
How to make Roller Spring Perches
Old Dec 31, 2007 | 06:29 PM
baddog671's Avatar
baddog671
ORIGINAL: green_blurr
I wouldnt go with poly-type bushings. They offer better handling, but are stiff as all hell, squeek, and can damage some suspension parts. I'd rather go with the rubber..
Old Dec 31, 2007 | 07:51 PM
Shrinkdude's Avatar
Shrinkdude
I bought the kit to make my own. It wasn't too bad, I had to rehone it alot since I am not the best welder.[&:]
Gene K
Oct 21, 2015 11:37 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
degner122
Sep 16, 2015 07:09 AM
Sparks_88
Sep 8, 2015 01:06 PM
Sep 8, 2015 11:50 AM
