stick shift
Old Jan 10, 2008 | 07:53 PM
Indy65's Avatar
Indy65
Default stick shift
I just purchased a 65 Mustang, have driven it a few times. Admittedly I'm a beginner at stick shift. However, it is now sitting in my garage and I'm having a problem with the stick. I can't seem to shift into different gears. When I try to move from gear to gear the stick is blocked from going into 1,2, 3,4 etc. But, I think it is in gear as when I lift up the clutch the car moves forward slightly, but it seems like it's in neutral when I'm moving around the stick. I can't idle without the clutch depressed. Any suggestions would be appreciated. The owner is a friend and never had that happen to him (but is in a different city so can't come over & check it out).
[IMG]local://upfiles/88141/313D5251F24D47BB91E3FDD1C96E1E59.jpg[/IMG]
Old Jan 10, 2008 | 07:57 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: stick shift
is it an original shifter with the reverse lock out?
Old Jan 10, 2008 | 08:12 PM
Starfury's Avatar
Starfury
Shifter linkage probably needs adjustment This is a good time to go get yourself a Factory Service Manual to learn how. Lacking that, set the front on jack stands and come back here for an explanation.
Old Jan 10, 2008 | 08:15 PM
flyingfool's Avatar
flyingfool
hmm, perhaps the clutch linkage is out of place? i know my clutch is on its way south...sometimes it makes my transmission slam fist gear becasue itdosent clear allthe way.
when you have it in "gear" how much sideways movment is there in the shifter? if its just a little, id say thats normal for the shifter. I am assuming that your car just dies without any gringing when you take your foot off the clutch when in Neutral?
Old Jan 10, 2008 | 08:30 PM
Starfury's Avatar
Starfury
If the clutch wasn't disengaging completely, you'd still be able to shift gears with the engine off. You'd also get grinding when trying to shift gears with the engine running, not a completely blocked shift.
Old Jan 11, 2008 | 08:40 AM
blue66mustang's Avatar
blue66mustang
Please set all FOUR corners on jackstands. Your new at the whole clutch thing per your first post. I'd really hate to see you make a mistake with the shifter/clutch/linkage and dump it off the stands and damage either yourself or the car.
FWIW.
Old Jan 11, 2008 | 09:05 AM
mustangmatt63's Avatar
mustangmatt63
Sounds like the linkage is either hung up or out of adjustment!! Go get a book on it as now is a good time to learn and I agree with blue66mustang,if you have never worked on something with a stick either jack all 4 corners or at the very least get someone to help that knows what they are doing!! I would like to have you around for a few more posts not DEAD because a car fell on top of you!![8D]PS WELCOME!!
Old Jan 11, 2008 | 10:01 AM
03Maverik's Avatar
03Maverik
mustangmatt63
Take it easy on him. You don't wanna scare him away!!! But seriously, Indy65 get yourself a book. That way you can learn about your whole car. Keep asking questions, lots of useful and iformative guys on here that enjoy Mustangs.
And WELCOME TO THE SITE!!!
Old Jan 11, 2008 | 11:47 AM
Starfury's Avatar
Starfury
Sorry, I assumed he knew enough to block the back wheels before jacking the car up. You don't really need to set it on 4 jack stands. I never rely on the tranny staying in gear to keep the back end from rolling while I'm under the car.
Old Jan 11, 2008 | 01:14 PM
HGC's Avatar
HGC
A lot of good suggestions here for you follow. One more thing you could try is double clutching. Depress the clutch and shift out of gear. Release the clutch and then depress it again to shift into the next gear. This is not necessary on a car where the clutch and transmission is operating properly, but in my old 69 years ago I had to do it for a while to get around a problem with with syncros. However, my problem was two fold - it was difficult to get into the next gear AND I would sometimes get a gear grinding noise as it went in. I am tending to lean towards the loose or out of adjustment linkage suggested by the others here.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
BeatnikFink
Oct 1, 2015 08:00 PM
wraith777
Sep 28, 2015 10:49 AM
