performance upgrades?
Old Jan 14, 2008 | 08:43 PM
67mustang302's Avatar
67mustang302
Default RE: performance upgrades?
Heads.
Old Jan 14, 2008 | 08:44 PM
Starfury's Avatar
Starfury
2-1/4" is the perfect size pipe for that engine. I wouldn't push it out to 2-1/2 unless he gets it up over 350hp.
Old Jan 14, 2008 | 09:07 PM
BULLITT GT 390's Avatar
BULLITT GT 390
I have a 68302 that I'm puting in my 67 not going to mess with the numbers maching engine!!I'm going to put a edelbrock performer rpm top end kit on it it sould be go for 350 to 365HPhttp://store.summitracing.com/partde...p;autoview=sku
good luck....
Old Jan 14, 2008 | 09:10 PM
BULLITT GT 390
it works with the stock engine!! and you can mod it later down the line thats what I plan on doing...
Old Jan 14, 2008 | 10:23 PM
ninteen66mustang's Avatar
ninteen66mustang
You should tell us your price range. If you dont have one:
TWIN TURBOS
Old Jan 14, 2008 | 10:28 PM
dugan's Avatar
dugan
my price range is as cheap as possible right now
but i would also like ideas where price is no object just so i no what to do down the road
Old Jan 15, 2008 | 12:15 AM
andrewmp6's Avatar
andrewmp6
Monte carlo bar and export brace both are cheap and stiffen up the front end alot.
Old Jan 15, 2008 | 01:53 PM
dugan's Avatar
dugan
so should i keep my stock heads and them moddified? if so what should i have done? or should i just buy performance heads for it?
Old Jan 15, 2008 | 02:47 PM
jlg2002's Avatar
jlg2002
Aftermarket heads are best, but pricey. BTW, headers are the best bang for the buck for a bolt on performance increase that you can feel.
Old Jan 15, 2008 | 06:05 PM
Starfury's Avatar
Starfury
IMO it's not worth it to put money into the stock heads unless you absolutely want the original heads. For a complete rebuild includingbigger valves, hardened seats,pushrod guideplates, screw in studs, springs, and some mild porting, expect to spend a good $600-800 and come out with a set of heads with a mediocre flow rate. For a couple hundred more you can get a set of World Products Windsor Jr's that will flow better (damn well for cast heads) out of the box, and for a couple hundred more than that you can get a set of even better flowing aluminum heads.
I'd wait to do the cam until you can afford heads. The cam and heads should be matched to eachother performance-wise.
