part cleaning help
Old Jan 21, 2008 | 09:04 AM
blue289's Avatar
blue289
Default part cleaning help
does anyone know of a good solvent for cleaning brackets and pulleys? Once they are clean, should I repaint them or what?
Old Jan 21, 2008 | 09:30 AM
66FB06GT's Avatar
66FB06GT
Default RE: part cleaning help
For smaller parts I have a can of Berryman's part cleaner (should be able to find it at your local parts dealer). Here is a link:
http://www.berrymanproducts.com/Default.aspx?tabid=146
I also put some parts into a tumbler that I have to get surface rust and other junk off of it w/o too much effort. Bigger parts I use the old method of wire brush in my drill.
Hope this helps.
Old Jan 21, 2008 | 10:04 AM
Starfury's Avatar
Starfury
Yeah, carb cleaner works fairly well. Keep in mind, it will leave a residue. Once you've got them clean, I'd go over them with brakleen or lacquer thinner before painting them semi-gloss black.
Old Jan 21, 2008 | 10:41 AM
mustangmatt63's Avatar
mustangmatt63
I usually just use a wire brush in a drill to remove the heavy stuff and then clean them with laquer thinner before painting them!
Old Jan 21, 2008 | 10:58 AM
Adrenolin's Avatar
Adrenolin
All depends on how dirty they and and the dirt. General light cleaning I use Dawn dish soap. Spray it with brakeclean if its tougher and if that doesn't do it grinder/drill with a wirewheel. SOS pads/steelwool is cheap and works great also.
Old Jan 21, 2008 | 03:26 PM
jlg2002's Avatar
jlg2002
I use standard paint thinner, available at the hardware store for about 5 bucks a gallon. It disolves grease and grime pretty good. It is flammable, so use in a well ventilated area without a source of ignition. After clean up, paint the pulleys with a nice black lacquer ( spray can).
Old Jan 21, 2008 | 05:16 PM
FastFox's Avatar
FastFox
I always use Simple Green to clean any grease or oil off my parts. Then as mentioned earlier, I will rub everything down with a thinner before painting. I will thenspray the pieces with a primer, wait three days, then paint.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
MusicCity615
Sep 12, 2015 07:05 AM
kevsgt
Sep 9, 2015 06:20 AM
