67 Coupe, Almost a Daily Driver
Just added:
-MSD on board timing control
-2.5 exhaust w/cutouts and Hooker COMP headers
-17X8/17X9 Coy's C-67
This month:
Install: Wilwood front disk conv.
Install: Globalwest tubular subframe con.
February:
Rear Qtrs and Paint
Sounds like you are on the right path!!Post up some pics when you can!Would love to see the car as it comes along!![sm=signs003.gif]
[IMG]local://upfiles/72436/A74D24B535BF407CA7A2D1B4B80FA436.jpg[/IMG]
other items:
-Edelbrock A/F meter (see inside)
-shelby decklid and endcaps
-280H cam
-Gear Drive
-Pro Comp mini HEI (removed vac advance)
Also Installing:
-65 289 heads with 54CC chambers and 1.94/1.60 valves
-280H cam
-Gear Drive
Also Installing:
Hey Batman
When you put the shelby decklid and end caps on how did you handle the gap thats left between the endcaps and taillight panel?
I just ordered the Shelby kit from Branda and was told you need to either fill it or buy an aftermarket panel to weld in. I do not want fill on the car but cant find the aftermarket item anywhere. Was told NPD has it but I'm not sure which part it is.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
