cd player install
Old Mar 26, 2005 | 03:52 AM
jman67's Avatar
jman67
Default cd player install
I want to install a cd player in my 67. Can anyone tell me how to wire it. I see there is only 4 wires going to the stock radio one is for the power one is for the light and two are for the speaker. I know I will have to run my own speaker wires but I am not sure which wires get connected to what on the new cd player.
Old Mar 27, 2005 | 04:59 PM
6mustang6's Avatar
6mustang6
Default RE: cd player install
You will probably be better off running new wires to it. Run a power line to the fuse box, then run a ground wire and ground it somewhere to the car. oops forgot, you also have to run a memory wire to the fuse box, it has to have a constant supply of power. The other power wire needs to get power when the car is turned on. I just stick the wire in between the fuse and fuse box. Hope this helps!
Old Mar 27, 2005 | 05:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you had a radio in it before, you will still have positive and negative wires there. The positive goes to the ignition switch so the radio/cd player is turned off when you shut down.
Old Mar 27, 2005 | 09:11 PM
fats429's Avatar
fats429
I try from memory
red= iggy hot
yellow=constant hot / memory
black = ground
greay , green , white , purple are speakers witch is front & rear I dont remeber work it out with the fade and ballance to know for shure . fade all the way front and ballance allway right hook up the speaker wires until you get sound that is the front right and so on . the pos / neg on the speaker wires is the solid color is the + speaker & the color and black stripe is -
The blue wire is for power out to acc. If you ant running a amp or something like that it dont get used
Old Mar 27, 2005 | 09:53 PM
jman67's Avatar
jman67
ORIGINAL: fats429
I try from memory
red= iggy hot
black = ground
I have already run wires for the ground and constant but I need to connect the red wire to a switched source. do you know which wire is a switched wire
Old Mar 27, 2005 | 10:04 PM
fats429's Avatar
fats429
would not jump off a nother wire under thare . run a nothet one from the fuse block if you are out of room you could just tie it in to the constant hot . It wont hurt nothing all that will happen is the radio wont shut off when you turn the key off .
Old Mar 28, 2005 | 12:42 AM
Dan66's Avatar
Dan66
ORIGINAL: jman67
...I need to connect the red wire to a switched source.
I attached mine directly to the back of the ignition switch.
Old Mar 28, 2005 | 10:55 PM
jman67's Avatar
jman67
I will give that a try. are you talking about the nut on the back of the ignition
Old Sep 23, 2016 | 07:46 PM
buckeyesuave's Avatar
buckeyesuave
Hey JMAN! Was this something that you owned?
It is my old car and I recently bought it back after 30 years and I am looking to find out about its history. Please email me at buckeyesuave@yahoo.com thanks!!
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
