Surprise rust hole - updated finished pics
Scroll down for new pics in reply post.
Getting her ready for paint. So I sanded down the lower front fender where there was rust. Right side was fine. Got the rust off - a skim coat of Bondo for some minor surface pitting and then primer. Right side looked a little rougher. Kept sanding. Saw daylight. Took it down to the metal inside and out and found this. Not really too bad. Very localized. An inch outside the affected area is good metal. Even the edges of the fender look pretty decent as you can see in the photo. I figure a quarter inch of Bondo on the insideshould do it.Just Kidding!!!! Think I'll cut it out an inch or so outside the holes and put it a patch. There is some pitting and stain but the inside actually looks better than the picture shows. The previous owner cleaned and painted the underside every few years but something must have gotten under the paint right here. Not being a welder I thought I'd try some 3M Panel Bond here. Make a little patch, flange the edges and bond it in so the exterior of the patch is flush with the surface of the fender.
[IMG]local://upfiles/82474/BD52A3E19F3749F0B62D9648E1C208B3.jpg[/IMG]
[IMG]local://upfiles/82474/660DF3C7C2A845F282A33721E9364205.jpg[/IMG]
[IMG]local://upfiles/82474/0069E28BE9E24EAB8280CF1F736F813B.jpg[/IMG]
RE: Surprise rust hole
You really need to clean that area good or you're asking that rust to come back. If it was me I would take it and have the lower section blasted carefully and then roughen the back and use "All Metal" from the backside and then use reg filler on the front side. No matter which way you decide fiberglass or Metal filler make sure it's damn clean or it will come back and ruin your paint.
What's "All Metal?" Is that a filler? I still need something solid for backing don't I? It will be down to shiny metal before I do anything. For some reason the shadows make it all look dark, even where it is good. There are still specks of rust in thepits which I have to get out but most of the surface is actually clean.
If it were me I would first sand blast< then weld(mig) in some metal,(careful with the voltage)grind down with 36# then put a light coat of 3m glazing putty. finish sanding with 320# prime and paint. If that does'nt work clean metal up real good, of course,fiberglass inside, glazing putty outside(no more than a 1/8 of an inch thicknessof putty) sand, prime and paint.
I use "All Metal" because it has small metal particles in it and is alot stornger than just body filler.
All Metal is like filler in that you have to mix it with hardener. When it sets up it is like a rock. You can get it at most every body paint store. The reason I don't use fiberglass is because in that area you are doing it can and will get moisture on it and eventually get under the glass and lift. I would get that area blasted or something to eliminate the rust then use which every you decide to use. I would not enlarge the holes, you do not need to if it's been cleaned.
oh thats nothing, you should have seen my car!!! rust holes and bad patches on every corner... suprisingly the fenders were the only good panels...
make sure to check your doors and quarter panels as those tend to rust even more.
