which backspace to choose ?
Old Feb 2, 2008 | 04:20 PM
kalli's Avatar
kalli
Default which backspace to choose ?
Hi all,
am in process upgrading to 5 lug. getting rear axle from quickperformanceracing if anyone knows them.
There will be 11" disc brakes coming with the axle.
for the front i decided for the discbrakeswap kit.
Now i'm thinking about what wheels to get (unfortunately can't keep the old 4lugs, which will make this expensive).
So that's what I think about getting:
http://store.summitracing.com/egnsea...=KeywordSearch
cragar quick trick I, 15x7" 5x4.5" bolt circle should be ok as far as I know.
But there are 2 different ones: 3.75" backspace and 4.5" backspace.
which ones should I get ?
Anyone any idea ?
thanks,
Kalli
Old Feb 2, 2008 | 04:41 PM
stangimgood's Avatar
stangimgood
Default RE: which backspace to choose ?
i think you'll need the 4.5 to clear your disc brake set-up.... if memory serves me correct......
or was that the fender.... i'm old and the memory..... what was i talking about?
Old Feb 2, 2008 | 04:59 PM
kalli's Avatar
kalli
probably going for 225/60R15 BF goodrich radial T/As in rear and probably 205/60R15 in front (no powersteering)
if that helps anything ....
Old Feb 2, 2008 | 05:06 PM
stangimgood
Kalli that is the same set-up i am using on our 65..... the only difference is i used cragar ss wheels...they only come with 4.25 back space and i would have loved to have that xtra .25 inch to clear the wheelwell on drivers side..... without power steering will it be a little hard steering with that size tire on front? i was thinking about our 69 camero and that size tire being a tough one for the wife to drive......just curious
Old Feb 2, 2008 | 05:35 PM
kalli's Avatar
kalli
thatnks for info :-) do you have pictures of the current setup ? would love to see that. it'll be awkward steering alright, so I'm not sure about 195 or 205 yet. currently driving 195 in the front
Kalli
Old Feb 2, 2008 | 08:07 PM
dodgestang's Avatar
dodgestang
15x7 with 4.5 backspace will run into hard interference with the upper a arm. 4.25 is generally the max backspace you can run with a 7 inch wheel
Old Feb 3, 2008 | 07:26 AM
stangimgood
Kalli.... did you receive the pics? hope they were of use....
Old Feb 3, 2008 | 01:28 PM
kalli's Avatar
kalli
yes. received them alright :-) thanks !!!
dodgestang: so you're saying I should go for the 3.75" backspace ? I really have no idea. I just want them to fit.
Kalli
Old Feb 3, 2008 | 03:08 PM
kalli's Avatar
kalli
actually I found dodgestangs charts:
http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
there are a few references which say 15x7, 3.75" all bone stock should fit
Nice one. that's another decision made ... slowly but surely getting it together
Kalli
Old Feb 3, 2008 | 03:37 PM
zmetalmilitia's Avatar
zmetalmilitia
I know this bs deal can be frustrating not knowing if the wheels will fit. I am going through the same process, ordered wheels, but I won't know for sure until I bolt them on. You just need to do as much homework as you can with what you have on your car. My setupis somewhat custom, so I had to measure the bs of the car. That way I knew what would fit and what wouldn't. Good luck.
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
whatsup62
Aug 29, 2015 01:25 PM
Gary Ugarek
Aug 26, 2015 08:41 AM
WAstang2013
Wheels & Tires
Aug 12, 2015 08:19 PM
