starting engine with NO transmission
Old Feb 5, 2008 | 08:31 PM
jamieNerikas66stang's Avatar
jamieNerikas66stang
Default starting engine with NO transmission
ok...my new crate engine will be here in one week, i am with super limited space, and limited time on borrowed engine lift, my engine bay has just been painted and engine is ready to go in,...however...the people that are rebuilding my C4 trans are not ready for me to drop it off till next week and will take 2-3 week for turn around, he is super busy,...but has a great reputation so its worth the wait to me,...
my question is, can i drop the engine in and get everything hooked up, headers and all, and start the engine and make sure everything is working right while the trans mission is at the shop,...what would be needed to do this,...just the flex plate, bell housing, and starter?,....
Old Feb 5, 2008 | 08:32 PM
dodgestang's Avatar
dodgestang
Default RE: starting engine with NO transmission
Wait for the transmission.
Nothing worse than unbolting your headers because the tranmission won't bolt up.
Old Feb 5, 2008 | 08:39 PM
68goldstang's Avatar
68goldstang
I wouldn't be in a hurry. It will be hard on the mounts by starting it without the trans. I don't see the reason anyway. Wait and do it all at one time, far less problems.
Old Feb 5, 2008 | 08:46 PM
jamieNerikas66stang
ok, any problems is letting crate motor sit for a couple week to a month, without being started? anything i should do?,...
Old Feb 5, 2008 | 09:05 PM
mustanglover66's Avatar
mustanglover66
There no problem letting it sit for a while as long as its protected from the weather like inside a garage. We have motors sitting in our shop longer than that waiting for customers to pay for they.
Old Feb 5, 2008 | 09:13 PM
jamieNerikas66stang
it will be in the car, sitting in the garage,...should i put all fluids in?
Old Feb 5, 2008 | 09:20 PM
mustanglover66
you can put oil it if you want it would just sit in the oil pan though. I don't know how you can get anti freeze in the block without starting it.
Old Feb 5, 2008 | 09:22 PM
dodgestang's Avatar
dodgestang
ORIGINAL: jamieNerikas66stang
No.
Old Feb 6, 2008 | 08:55 AM
urban_cowboy's Avatar
urban_cowboy
ORIGINAL: dodgestang
+1...I cannot get my tranny in or out with my long tube headers on. The bell housing will not clear. I would wait.
Old Feb 6, 2008 | 11:53 AM
ky's Avatar
ky
America ftw
theres no problem starting the engine with no tranny. you can actually find problems that need to be fixed that way. for instance, i work at an engine machine shop, and my dad got his motor/tranny all back together. both were fresh rebuilds, but theres a bad vibration. so my boss says disconnect the flyweel from the converter and slide the tranny back and start the engine. if the vibration stops, then you know the problem is the tranny. if its still there, then you know the trannys fine and it is a balancing problem then.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Nexuia
Aug 23, 2015 11:30 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
