Axel Removal
Old Feb 10, 2008 | 10:17 AM
arkight's Avatar
arkight
Default Axel Removal
I was wondering if anyone new a website that showed how to remove an Axel from a ford 9". I bought the shop manual for my '69 but it dosent work on my computer for some reason the CD worked fine at work but not a home. I am buyinga new pumpkin and i just wantto make sure i get the correct spline.
Old Feb 10, 2008 | 10:35 AM
baddog671's Avatar
baddog671
Default RE: Axel Removal
Take the drums off. There are 4 bolts on the backing plate that need removed and they are in a square formation, take them out. Then PULL and they should popout.
Old Feb 10, 2008 | 07:19 PM
zmetalmilitia's Avatar
zmetalmilitia
If you go to the curriw website, under crate rearends, they show how do remove and replace a rear end. It isn't a Ford Mustang but the idea is the same. It's on a chevelle.
http://www.currieenterprises.com/cestore/chevelle_install.pdf
Old Feb 10, 2008 | 07:38 PM
arkight's Avatar
arkight
Thanks i found this one
http://classicbroncos.com/rear_axle_removal.shtml
didnt have a chance to do it though.
What about fluid will any fluid come out of the differental if i pull one of the axle's out?
Old Feb 10, 2008 | 10:11 PM
Aussie66Fastback's Avatar
Aussie66Fastback
should be no diff oil coming out with the axlesunless the thing was somehow overfilled (or you have it sitting on a real bad angle)
Old Feb 11, 2008 | 08:45 AM
Gary H's Avatar
Gary H
If they dont come out, you might need a slide hammer.
Old Feb 11, 2008 | 11:30 AM
racin66coupe's Avatar
racin66coupe
ORIGINAL: Gary H
hey! i was gunna say that!
Old Feb 11, 2008 | 12:37 PM
TexasAxMan's Avatar
TexasAxMan
Instead of the slide hammer, do what was suggested to me and worked.
Put one of the drums on backward with 3 or so lug nuts, hit the back side with a sledge hammer. Worked like a champ. Thanks to whoever it was that suggested it to me.
Old Feb 11, 2008 | 12:47 PM
baddog671's Avatar
baddog671
Ive also seen someone on here hook a chain to one of the studs to get leverage...
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
wawagner82
Sep 13, 2015 09:02 AM
