automatic to stick help!!!
Old Feb 11, 2008 | 10:37 PM
07grabberstang's Avatar
07grabberstang
Default automatic to stick help!!!
hello everyone, I have a 1968 289 automatic mustang which I want to convert to stick shift. I have a donor car which is a 1968, 200 6cyl stick shift everything is there and in petty good shape. my question is, will the gear box from the six cylinder bolt up to the 289 motor ?
before I start this conversion just want to know what I should be prepared for? any information would be appreciated thank you for help
Old Feb 11, 2008 | 10:51 PM
ky's Avatar
ky
America ftw
Default RE: automatic to stick help!!!
no you need a v8 tranny.
Old Feb 11, 2008 | 11:58 PM
jlp66stang's Avatar
jlp66stang
At least a V8 bellhousing!
Old Feb 12, 2008 | 12:04 AM
DanK69RustangVert's Avatar
DanK69RustangVert
ORIGINAL: jlp66stang
+1 - Except, the 6cyl.s were often 3 speeds, what do you have, and waht do you want? Most want the 4 sp. for the 289.
Old Feb 12, 2008 | 12:32 AM
07grabberstang
well the donor gear box is 3 spd but that doesnt matter i can up grade later as long as it makes my car a stick shift cause i dont like automatic cars. this gives me time to save up for a t5. i just want to drive my car
Old Feb 12, 2008 | 12:35 AM
andrewmp6's Avatar
andrewmp6
And the inline6 one is geared differently get you a toploader or t5.
Old Feb 12, 2008 | 01:25 AM
07grabberstang
ok so i could use erything else like the pedals crossmenber but use a t5 from a 89 5.0 or forget this donor car and get a swap from a vender which is like 5 grand
Old Feb 12, 2008 | 03:57 AM
andrewmp6's Avatar
andrewmp6
Crossmember won't work need to buy one or make one and some little things.
b8checker
Oct 8, 2015 12:55 PM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
