alternate grounding points
Old Feb 16, 2008 | 01:52 PM
flyingfool's Avatar
flyingfool
Default alternate grounding points
so the big brown mustang truck brought my tach yesterday (from summit) and it says its best to run the black wire to the - battery terminal, yet they put a short little length of wire on there that i dont think can reach across my car![:@] it says you CAN run to alternate gorund, but they dont recomend it. anyway, whats a good source for ground?
Old Feb 16, 2008 | 02:21 PM
JamesW's Avatar
JamesW
Default RE: alternate grounding points
Ground it solidly to the metal dash.
Old Feb 16, 2008 | 04:28 PM
wrenchturner75's Avatar
wrenchturner75
yea ive always used the dash and they worked fine, wher are you putting it if you dont mind me asking, i have a 71 that has the factory tach but ireally dont think its all that accurate, and though about puttin one in but where to stuff the damn thing?
Old Feb 16, 2008 | 04:32 PM
Adrenolin's Avatar
Adrenolin
Which tach did you go with? I'm looking at the 5" Auto Meter 1499 8K tach from summit.
Old Feb 16, 2008 | 06:26 PM
flyingfool's Avatar
flyingfool
I went with sunpro II. its a little thing, 2 5/8". theres not a lot of room on the 70s for them and its tightso small is good. im putting it on the leftside ofsteering column. even though it isnt hooked up yet, i kinda drove around with it on there kinda loose so i can see where i like it. they say just put it on there with a hose clamp...but ihave to say, it looks kinda bad like that, even painted.
about the grounding, would just putting abolt through the dash and screwing itin beenough, or should i try to round up some soldering stuff?
Old Feb 16, 2008 | 06:41 PM
wrenchturner75
all i ever did was install an eyelet to the end of the wire and drill a small hole if there wasnt one already to the very bottom part of the dash, in other words you couldnt even see it sitting in the drivers seat. and use a small sheetmetal screw then dab a coat of paint on the screw head. but i agree on the hose clamp deal it looks horrible, i have an older 5" auto meter monstaer tach, but i have nowhere to put it, my coupe has a factory tach, has the full guage package, has a/c so it has dash vents, and a full length floor console. as a matter of fact im gonna put up a post to see what some other guys did.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
