Side Scoops
Old Feb 18, 2008 | 03:44 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Side Scoops
Do you have to drill a hole into the side of the car to put side scoops on? Or do you just have a bracket the gets put in the holes?
Old Feb 18, 2008 | 04:19 PM
SalikDDD's Avatar
SalikDDD
Default RE: Side Scoops
i have em for my 67 haven't put em on yet but they're apparently held on with a bolt... i'm kinda wary about drilling into the car but.. anything is better than the 2 crap looking "fake" scallop things on the side.
Old Feb 18, 2008 | 04:29 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you can either pop rivet them on or use panel bonding adhesive
Old Feb 18, 2008 | 06:34 PM
valley firearms's Avatar
valley firearms
The aftermarket scoops have studs bonded to them. You must drill a hole in the side of your quarter panel to mount the scoop. As I was doing mine I found that their bonding agent sucked and the stud popped right off the back of the scoop. I went to Lowes and got some new 2 part epoxy and even added a stud making it a total of two per scoop. I had to do the addition because the scoop did not conform to the quarter panel and I actually had to suck the back of the scoop into the panel. You also have to fit the scoops to the car.
[align=left] [/align]
[IMG]local://upfiles/21693/A19529179E704EACB2EA1C541252E491.jpg[/IMG]
Old Feb 18, 2008 | 07:57 PM
Adrenolin's Avatar
Adrenolin
Please note... It depends on which scoops you bought! There are functional and non-functional side scoops. Yes I'm assuming you are talking about the lower side scoops. The non-functional scoops bolt. I've seen some that didn't have the studs bonded on in which case you'd have to bond them to the car. If you ordered the functional scoops (like I did) then yes you do need to cut a hole as they have a 'port' that goes through the body panel for the 'duct works'.
I have the 67 lower functional side scoops from Branda Performance. I'd take a picture for you however they are over at the garage right now.
Hope this answers your question.
Old Feb 18, 2008 | 08:07 PM
valley firearms
Check out this site for bonding agents. Dyna-Weld is a good product for what you are doing.
http://www.autobodystore.com/FillerMatls.shtml
Old Feb 18, 2008 | 09:01 PM
1slow67's Avatar
1slow67
ROTM Moderator
I'm not getting them since I would have to drill into the body. Im either getting new leaf springs or a new carb setup.
Old Feb 18, 2008 | 09:06 PM
Adrenolin's Avatar
Adrenolin
You could buy the non-functional scoops and simply bond them to the car.See VF's post above for the bonding agents.
Old Feb 18, 2008 | 09:09 PM
1slow67's Avatar
1slow67
ROTM Moderator
I saw it. Not sure about that either. I'm not getting the car painted for about another 2 years.
Old Feb 18, 2008 | 09:25 PM
Mustang Dad's Avatar
Mustang Dad
I used the bond on style......used a few dabs of 5-minute epoxy to hold them in place and then fiberglassed and bondo aroudn them....looks pretty good. I saw a '65 coupe a couple of weeks ago that had a GT350 hood scoop bonded on, the rear quarter extentions bonded on and the rear lower valance bonded on. Looks smooth and slick....then I looked at his side scoops...they were bolt on's and didnt line up real well.....detracted from the over all looks of the car. If you get the side scoops, get the bond on style, you'll be happier in the long run.
PaulH2
20
Jan 31, 2016 09:48 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
jrrhd73must
Oct 2, 2015 09:17 PM
ChampInSD
Oct 2, 2015 04:55 AM
Drastang
Sep 29, 2015 03:31 PM
