electric choke carb ?
Old Feb 20, 2008 | 02:54 AM
eep4life's Avatar
eep4life
Default electric choke carb ?
so i have my my carb with an electric choke. i was wondering, where is the best place to hook the positve line to for the choke?
Old Feb 20, 2008 | 05:22 AM
kalli's Avatar
kalli
Default RE: electric choke carb ?
there has been a posting already about that.
Maybe we can move that to the FAQ:
https://mustangforums.com/m_4238503/tm.htm
Old Feb 20, 2008 | 09:15 AM
urban_cowboy's Avatar
urban_cowboy
I suggest connecting it to the small post on the starter soleniod that is on only when the ignition key is turned on. There are two small posts. The other small post is only on when you turn the key to start. Do not connect it to the large posts.
Old Feb 20, 2008 | 09:37 AM
my77stang's Avatar
my77stang
isnt it supposed to run off the alternator?
Old Feb 20, 2008 | 09:40 AM
4reboy's Avatar
4reboy
the stud on the alternator and coil don't produce a full 12 volts people told me when doing mine. I ran mine to the switched power on my windshield wiper motor. It was closest and most accessible for me, since I have a removable cowl panel.
Old Feb 20, 2008 | 09:54 AM
kalli's Avatar
kalli
it;s supposed to run from the post on alternator.
I don't know why this one would not supply 12V, doesn't make much sense to me.,
Best idea is probably to measure the voltage on the alt stud where it's supposed to connect to.
Connecting it to the alt has the huge advantage that the thing only runs when the erngine is running, not when you turn on ignition.
Kalli
Old Feb 20, 2008 | 10:17 AM
urban_cowboy
True, the alternator post would be a good place. I checked my soleniod post and they are all afull 12v when on. Not sure why it would not be.
Old Feb 20, 2008 | 12:41 PM
67mustang302's Avatar
67mustang302
+1 on the alt, that way it's only got heat when the alt is turning. As long as it has 0 volts when the engine is off and continuous 12v when running, you're fine.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
uberstang1
Sep 20, 2015 06:42 PM
