1968 Leaf Spring
Old Feb 21, 2008 | 10:06 PM
71mopar383's Avatar
71mopar383
Default 1968 Leaf Spring
We put new 4 leaf, leaf spring, shackles, ubolts, shockson the rear of our 68 Fastback and it still sits low and rubs the tires. They are 235-60's on a 7 inch wheel with a 4 inch back spacing. I cant have anyone in the back seat or they rub. It still sits higher in the front than the back, actually you cant tell a difference between the old springs and new. I dont wanna use air shocks. Air ride technologies setup is over 1500 bucks. Any suggestions?[:@]
Old Feb 21, 2008 | 10:41 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: 1968 Leaf Spring
standard, mid or reverse eye?
what's in the front?
where do you live?
Old Feb 21, 2008 | 10:52 PM
71mopar383's Avatar
71mopar383
Standard
stock coils
Ft Worth TX
Old Feb 22, 2008 | 12:01 AM
valley firearms's Avatar
valley firearms
I'm having the same problem. I have not done anything about it yet. I dread the bumps!
[align=left] [/align]
Old Feb 22, 2008 | 09:47 AM
nassaubayman's Avatar
nassaubayman
I just went through the same grief with my '67 Coupe. I bought new "stock" leaf springs, only to find out they made zero change to the ride height.
To get it the way I wanted it, I had to replace the front coils with 620 lb, 1" lower springs. Then I took the old set of leafs to a spring shop and had them re-arced +1.5". If I could do it again, I might have gone even more, maybe 1.75 or 2".
Here's a link with before and after pics.:
https://mustangforums.com/m_4403763/tm.htm
Old Feb 22, 2008 | 02:41 PM
blu66's Avatar
blu66
I have the same issues with my '66 coupe. I have not changed the leaf springs yet tho' but that is on the to-do list.
My front sits good, but I was wondering if the 1 1/2"' raised springs would do the same ting instead of buying stock then having them re arched. My rear tires are also 235/60 and I have CREAGERS all the way around.
Old Feb 22, 2008 | 02:53 PM
66FB06GT's Avatar
66FB06GT
I don't think I would have leafs re-arched, because the replacement ones are so inexpensive to begin with. I put 5-Leaf Mid-Eyes on mine for under $200. They were a pretty good match to my 620's that were cut to lower further. My wheels sit out on the fenders in the front and back, but the 5-Leafs are so strong I don't bottom out on bumps. I am surprised that stock springs didn't raise the back end if the original ones were sagging. That makes no sense.
Old Feb 23, 2008 | 07:32 AM
71mopar383's Avatar
71mopar383
We were not happy the it didnt change anything what is the advantage of putting a mid, lower, or upper eyed spring on one?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
