Advice on Repair
Old Feb 22, 2008 | 03:53 PM
AV8ForFun's Avatar
AV8ForFun
Default Advice on Repair
What can you guys recommend to repair this. On both sides of the engine bay, there are bad rust spots where the aprons front and rear aprons overlap the shock tower section....only on top. The battery apron on the other side is severely damaged and I am planning to replace it, but really am afraid to try to replace them all. At any rate the rest of them are solid except for these small spots where they overlap. Is there a possibility of patching these rust spots at the overlaps?
[IMG]local://upfiles/46913/77F3B9A1E9A349D18615FDD79987907F.jpg[/IMG]
Old Feb 22, 2008 | 03:56 PM
dodgestang's Avatar
dodgestang
Default RE: Advice on Repair
Sorry....I'm not seeing any bad rust spots there. I see a little surface discoloration and a lot of 40 yr old dirt. Maybe I'm not looking in the right spot...can you circle what you think the problem is?
Grind/sand it down to metal/smooth and paint it.
Old Feb 22, 2008 | 04:00 PM
AV8ForFun's Avatar
AV8ForFun
The top piece is rusted through in about a 1 inch circle at the point the two aprons overlap.
[IMG]local://upfiles/46913/E672D6770F2D4BA085756DFFBD4EF42C.jpg[/IMG]
Old Feb 22, 2008 | 04:02 PM
dodgestang's Avatar
dodgestang
There is a square hole at the top of the aprons where a capture nut clips into it that the fender then bolts to. From the picture I assumed it was the rusty remnants of the old caltured nut still clipped in place
Old Feb 22, 2008 | 04:05 PM
AV8ForFun's Avatar
AV8ForFun
So these places where the two aprons are spot welded together are supposed to have holes in them? I knew about the wholes with the clips used to bolt on the fender. Is that what you are talking about?
In the second attachment I circled the spots.
Old Feb 22, 2008 | 09:16 PM
68goldstang's Avatar
68goldstang
I must be the only one who can see the rust spots. It looks lke its rusting underneath the two panels. You won't be able to stop it unless you cut it out because it's actually rusting between the panels. I would cut the area out in a small square and weld a small patch piece in grinding it smooth. Thats just my thought
Old Feb 22, 2008 | 09:38 PM
AV8ForFun's Avatar
AV8ForFun
Yeah, I was hoping to be able to patch it without completely replacing all the apron sections. Since I'm going to replace the battery apron anyway. I may experiment with it first, and try to patch it.
I appreciate the advice.
If anyone has had this problem, let me know how you fixed it.
Old Feb 22, 2008 | 09:45 PM
jaw66's Avatar
jaw66
If you want to keep the seam you will have to make to patches per rust spot. would just make it smooth it was mine.
Old Feb 22, 2008 | 10:01 PM
AV8ForFun's Avatar
AV8ForFun
FYI, I just found this site explaining in Extreme detail how to repair this exact problem.
http://www.together.net/~groovygreen/page8/LE600_8.htm
I've been looking at this site, it is excellent. I know you guys have probably seen it before, but I just found it.....thanks for the advice guys.
Old Feb 23, 2008 | 02:36 PM
68goldstang
Yes thats exactly how I would tackle that repair. If you can mig weld you can do it.
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
