Block clearancing for 347.
Old Feb 22, 2008 | 11:00 PM
tyler72's Avatar
tyler72
Default Block clearancing for 347.
Has anybody here built a 347 themselves and trimmed he cylinder walls to clear the rods? I am about to order my kit soon, but I have to install this kit myself (I am a mechanic). I have heard that you have to clearance the bottom of the cylinder walls and was just wondering about the difficulty of this task. Any input?
Old Feb 22, 2008 | 11:28 PM
valley firearms's Avatar
valley firearms
Default RE: Block clearancing for 347.
I didn't do mine but it is very easy. You can do it with a dremel or a high speed grinder. You just need to grind the bottom of the cylinder wall to allow clearance for your rods.
[align=left] [/align]
Old Feb 22, 2008 | 11:29 PM
valley firearms
Here is mine.
[IMG]local://upfiles/21693/6F1D46C8C81345BD98AC7B4CEA968F1D.jpg[/IMG]
Old Feb 22, 2008 | 11:41 PM
tyler72's Avatar
tyler72
Thanks for the pics! That helps alot! It looks really nice in there with those hefty H beam rods!
Old Feb 22, 2008 | 11:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i believe coast high sells a template you can use to accomplish this but dont quote me on this i remember seeing it somewhere?
Old Feb 23, 2008 | 12:17 AM
tyler72's Avatar
tyler72
Yeah, some company sells a jig on ebay for 30 bucks I think, but that seems kinda steep to use one time. I will probably just put the crank in with one rod and just mark them all and grind them and just keep checking them until I have adequate clearance. But then again, that will take a long time and be a lot of extra work. The $30 is starting to sound better.
Old Feb 23, 2008 | 01:03 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
plus it keep you nice new parts from getting contaminated with metal shavings
Old Feb 23, 2008 | 07:51 PM
mustanglover66's Avatar
mustanglover66
Since I am a machinist at an engine shop I will tell you how we do it. Install a main bearing in the first, middle and last mains just the block side. Take your crank and set it in the block. Take 1 rod and install one piston on it without rings. take the rod cap and and bolt that will hit the cylinder and screw that bolt in to the using the cap to find the right height slide the rod into each cylinder and rotate the crank until the bolt hits the clyinder take a sharpe and draw a line around the bolt that is what you will grind out. after you mark all 8 cylinders remove the crank and main bearing then grind all 8 spots then put them back it to check your work.
Old Feb 23, 2008 | 08:25 PM
tyler72's Avatar
tyler72
Yeah, that is what I had in mind. Doesn't seem like too much work. I alos discovered that they want $17 to ship that template, for a total of $47. Screw that! Im not wasteing 50 bucks on a piece of sheetmetal that I don't need.
Old Feb 23, 2008 | 09:23 PM
Scott H.'s Avatar
Scott H.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
