smoking from value covers
Old Feb 25, 2008 | 08:33 PM
urban_cowboy's Avatar
urban_cowboy
Default RE: smoking from value covers
Correct me if I am wrong, but smoke from the breather or PCV is probably blow by. This is exhaust/partially burnt fuel fumes coming past the rings during compression, into the crank chamber and exiting out the heads via the breather/pcv. Theoretically, this should enter the intake via the pcv and get reburned, but if you have excess is blows around the seal. Since you have a fresh rebuild, you could have a ring that is not seating properly which could be creating your issue???. I know when my rings wore out, I started having smoke out the breather...blow by is a pain. Do a compression test or have someone do one to check for ring seal issues.
Old Feb 26, 2008 | 12:27 AM
fordification's Avatar
fordification
there's a grey area to this. some motors naturally have "blow by". my motor from rebuild, and a few others I know have crankcase pressure with full compression in all cylinders. if this is the nature, you just need a good valve cover baffle to prevent oil from entering through the pcv, and let the carb draw the steam.
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
RCS02v6
Sep 29, 2015 01:46 PM
MacSerio
Sep 27, 2015 01:05 PM
