fan thermostat
Old Mar 7, 2008 | 12:48 AM
eZ's Avatar
eZ
Default fan thermostat
What fan thermostat should i get for my electric fans on my 302. Ive decided to go with dual 12' fans.
Old Mar 7, 2008 | 10:49 AM
JMD's Avatar
JMD
Default RE: fan thermostat
We used this one,,,,
http://www.spalusa.com/ (Fan PWM)
I like it, starts at half speed and gradually goes to full speed as engine heat rises. If you get this one you will need the dual fan kit as well. With the dual fan setup, the second fan comes on when the primary fan reaches 100%.
Old Mar 7, 2008 | 10:20 PM
eZ's Avatar
eZ
why not splice them so they wotk together as one fan?
Old Mar 8, 2008 | 09:58 AM
JMD's Avatar
JMD
ORIGINAL: eZ
It is a solid state controller and the power draw is just too much to lay on one circuit.
Even with traditional controller relays, the best commonly usedrelays will only take about 30 amps. Depending on the fans, each one may draw as much as 30 amps. This is a huge draw. I willguess that each of your two fans will draw about 20 amps.
In short, I say whatever controller you choose, if it were me I would want a double relay to be incorporated into it's design. There are certainly cheaper controllers on the market, but I have not seen one that has more to offer in the coolness department.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
Sep 25, 2015 09:06 AM
MusicCity615
Sep 12, 2015 07:05 AM
