Spot welds :(
Old Mar 8, 2008 | 02:14 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Spot welds :(
I don't bother with a spot weld cutter if I'm taking off sheet metal from thicker metal, Like where the apron attaches to the shock tower or the frame rail. It is a waste of time. Use an air chisel. The thicker metal will not be harmed by the chisel and it saves a bunch of time. Once it is chiseled off clean it up with a grinder and you are ready to fit your new piece.
Old Mar 8, 2008 | 09:06 PM
zmetalmilitia's Avatar
zmetalmilitia
ORIGINAL: 67t5ponycoupe
That's the way I did 99.9% of my sheetmetal removal. It is a lot easier than trying to drill out every spot weld. Wear ear protection though, it can be LOUD! what?
Old Mar 8, 2008 | 11:23 PM
68goldstang's Avatar
68goldstang
I used a cutoff wheel and thinned the spotweld area then used the air chisel. Cut like butter. Had my right side apron out in like 20 mins. Drilled a few holes (5/16th) in the new apron and welded it in. Took the cutoff wheel and smoothed it out. Looks almost factory. I replaced both sides and had it all finished in a couple of hours.
mtgldr
Feb 3, 2024 09:00 PM
jrrhd73must
Oct 2, 2015 09:17 PM
popsotto
Sep 28, 2015 06:58 AM
ctgreddy
Sep 20, 2015 08:35 PM
Sep 17, 2015 07:57 PM
