Removing Door Panels
Old Mar 7, 2008 | 11:53 PM
unit91's Avatar
unit91
Default Removing Door Panels
How do you getdoor panels off without breaking the fasteners?Must be a trick to do it right. What's the secret? Help!!!
Old Mar 8, 2008 | 12:20 AM
atomsk680's Avatar
atomsk680
Default RE: Removing Door Panels
i believe there are spot welds running around the entire panel that you have too drill out
Old Mar 8, 2008 | 01:30 AM
unit91's Avatar
unit91
No, I mean the interior panels - the finish trim panels that the door latch and window crank poke out of. It's like a particleboard covered with fabric.
Old Mar 8, 2008 | 01:31 AM
atomsk680's Avatar
atomsk680
ooooo![&:] ok well what i did was get a long flathead and slipped it underneath and found the clips and gently tried to pry them out, i didnt break any, it might work for you, i think they make a tool for it too
Old Mar 8, 2008 | 01:34 AM
unit91's Avatar
unit91
OK......gotcha.......thanks.......
Old Mar 8, 2008 | 10:01 AM
zmetalmilitia's Avatar
zmetalmilitia
It takes a "feel" to get those tabs to snap out of there. Like the windshield tabs. tricky. It usually takes a special tool to get those out.
Old Mar 8, 2008 | 11:36 AM
Adrenolin's Avatar
Adrenolin
There is a special tool for this. Its called a Trim Removal Tool. Its designed for removing the chrome trim so you don't bend/damage the trim and brake the clips. Its also perfect for door panel removel. Looks like a small pry bar. Many uses while redoing a car and I recommend one in all tool boxes.
Here is a pic.. Typically sell for 5 to 15 bucks so pretty cheap.
[IMG]local://upfiles/78041/1FD1DDE6D3B543DDBCE8394E14021E1D.jpg[/IMG]
Old Mar 8, 2008 | 05:33 PM
unit91's Avatar
unit91
Roger that! Thanks......
Old Mar 8, 2008 | 05:42 PM
Coolerguy1965's Avatar
Coolerguy1965
I just use an old butter knife it seems to work better than a flathead or that tool.
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
