T5 not shifting
Old Mar 12, 2008 | 08:47 PM
6t9 stang's Avatar
6t9 stang
Default T5 not shifting
OK this may very well be a stupid question. I just got my t5 installed and at times it wont shift into gear; its not all the time and it's no specific gear. it is kinda spuratic. This is just with the carOFF mind you, I havnt driven it yetor even turned it on because this kinda worries me... Any ideas, I am clueless with manuals
Old Mar 12, 2008 | 08:51 PM
cmanf's Avatar
cmanf
Default RE: T5 not shifting
The clutch is the only thing that comes to mind.
My old toploader would shift into 3rd engine off but I had to push the clutch in to get it out.
Old Mar 12, 2008 | 09:06 PM
JMD's Avatar
JMD
If the car is not running, this is totally and completely normal!!
The gears kind of need to be in motion for the tranny to change effectivly...
The reason being is that when the tranny is not moving, some of the "gears" will be in a position where they will not slide together... in other words some of the "gears" are aligned "high spot to high spot" when they need to be "high spot to low spot" to properly engage.
"Gears" can also "lock" in the same fashion when the car is running but not moving and the clutch is pressed in. Often the clutch will have to be let up just a little to get things moving alittle before the tranny will go into gear.
This effect is more pronounced on a new tranny,than one withwear. Once they wear in a little this effect becomes less and less pronounced.
Old Mar 12, 2008 | 09:10 PM
JMD's Avatar
JMD
ORIGINAL: 6t9 stang
Incidentally, the reason this issue moves from gear to gear is because as the tranny is put into one gear, the shafts move just a little bit... this movement aligns one "gear" and un-aligns another..... and so on, and so on....
Old Mar 12, 2008 | 09:32 PM
flyingfool's Avatar
flyingfool
+ 1 on ^
and, if its a new or rebuilt trans, it might need a little breaking period of a couple days of driving.
Old Mar 12, 2008 | 10:12 PM
6t9 stang's Avatar
6t9 stang
Thanks alot guys, I was sweatin bullits there for a minute because like I said this is my first manual and I dont know Sh*$ about them
Old Mar 13, 2008 | 01:00 AM
JMD's Avatar
JMD
Yea,,, don't sweat it.... and also....
Damn nice looking car! Catches my eye everytime..
Old Mar 13, 2008 | 01:40 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
lol at you: sitting around granny shifting not double clutching like you should[8D]
Old Mar 13, 2008 | 06:45 AM
cmanf's Avatar
cmanf
ORIGINAL: rmodel65
LOL ROFLMAO!
I live my life 10 seconds @ a time.(In a 14 second mazda with 500lbs of stereo equipment in it.)
Old Mar 13, 2008 | 09:36 AM
6t9 stang's Avatar
6t9 stang
thanks alot JMD... Now with this swap complete I can check the last thing off of my to do list
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Mustangmalo
Sep 6, 2015 05:22 PM
