front suspension
Old Mar 13, 2008 | 11:25 AM
rtenman's Avatar
rtenman
Default front suspension
I'm restoring a 67 coupe(frame up). I have installed all new steering and front suspension.Its all back together, but my new shocks will not reach far enough to allow the two studs on the bottom of the shocks to bolt up. The engine and tranny is still out. Is this common?
Old Mar 13, 2008 | 11:31 AM
zmetalmilitia's Avatar
zmetalmilitia
Default RE: front suspension
No they should reach. Pics would help if there is an orientation issue.
Old Mar 13, 2008 | 11:45 AM
silverblue66's Avatar
silverblue66
Is the car on jackstands? I had the same issue if the tires were not on the ground, but just a 1/2 inch or so.
Kip
Old Mar 13, 2008 | 11:49 AM
racin66coupe's Avatar
racin66coupe
maybe jack up the control arms to make it reach?
Old Mar 13, 2008 | 12:12 PM
66JameStang's Avatar
66JameStang
If I understand right when the spring is placed on the upper control arm it is not tall enough to reach the top of the shock tower? Either you have the wrong springs or you just need to jack it up and attach the shocks to hold it is place... It seems kind of odd to me that the spring would be that short? Pictures would definitely help?
Old Mar 13, 2008 | 01:03 PM
TexasAxMan's Avatar
TexasAxMan
This may be stupid, but you have fully extended the shocks, right?
Old Mar 19, 2008 | 01:29 PM
rtenman's Avatar
rtenman
Problem solved. Jacking up the lower control arm was thje way to go,but because there was no weight on the frontend I had to collapse the spring a little to make it reach.
Old Mar 19, 2008 | 01:50 PM
racin66coupe
that was my idea!
Old Mar 19, 2008 | 02:07 PM
baddog671's Avatar
baddog671
ORIGINAL: rtenman
Yup, I had the same issue with my KYB's and using a jack to lift the suspension assembly about 1/2" was enough to fix the problem..
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Oct 3, 2015 06:23 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
