Question on 351 cleveland engine?
Old Mar 15, 2008 | 07:47 PM
XTREMECREATOR's Avatar
XTREMECREATOR
Default Question on 351 cleveland engine?
What is the difference between a 351 cleveland engine on a mustang and a 351 cleveland in a truck.
please let me know and what i have to do to make it a noce performance engine for a mustang if there is a difference.
i saw one at a junk yard for $150 tha is really clean.
thank you in advance for all you guys help.
Old Mar 15, 2008 | 08:59 PM
67mustang302's Avatar
67mustang302
Default RE: Question on 351 cleveland engine?
A 351W would make for a cheaper/easier build, depending on how much performance you're looking for. As far as the difference, the cam will prolly be different, which won't really matter since you'll replace that in a performance build anyway. And the carb/intake setup may be different as well, which again, you'll prolly want to replace in a performance build. All you're really looking for is the block and crank, and maybe the rods, and in a Cleveland, the heads. So, make sure the heads aren't bad, or that there are signs they may be bad, otherwise you're justing wasting time getting a Cleveland without heads.
Old Mar 15, 2008 | 09:19 PM
JBradley500's Avatar
JBradley500
the 351 in the truck is probably a 351m and there isnt much there that would help you out in mustang performance....parts will interchange but nothing performance wise.
in the early 70's ford designated the truck engine a 351c but it got too confusing so they changed the tall deck 351" engine a 351m(midland, modified, measley or whatever the m's for)
Old Mar 16, 2008 | 12:51 AM
Fordication's Avatar
Fordication
the M stood for Mexico. The 351M and many of the other Ms were made in Mexico and its similar but not the same as a 351C although both are considered mid to big blocks. Go figure.
Old Mar 16, 2008 | 01:36 AM
67mustang302
I always tell everyone the M stood for Morphodite, which is basically what the M blocks were.
Old Mar 16, 2008 | 01:39 AM
atomsk680's Avatar
atomsk680
M stands for modified
Old Mar 16, 2008 | 10:58 AM
Fordication
Sorry. I always heard the engine was built in Mexico. Must of been hearing things. Here isthe correct answer.
http://www.projectbronco.com/History..._ford_351m.htm
steelers743
Aug 31, 2015 07:16 AM
movielover40
Aug 27, 2015 10:13 PM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
HIS S-197
Aug 10, 2015 05:47 PM
89blueslug
Aug 10, 2015 07:20 AM
