I learned a good lesson today...
Old Apr 8, 2005 | 08:50 PM
1MeanMach's Avatar
1MeanMach
Default I learned a good lesson today...
Like so many other classics, my gas gauge doesn't work. Usually I'm good about keeping the tank full. But it was only a matter of time before driving past the gas station and saying "screw it" finally caught up with me.
My car started dieing just as I was coming up on the gas station, and gave up completely just before the entrance. Lucky I was moving fast enough to pop it into neutral and roll up to one of the tanks.
Not my best moment. I learned a good lesson today.
Old Apr 8, 2005 | 09:18 PM
FoMoCo_Jeppe's Avatar
FoMoCo_Jeppe
Default RE: I learned a good lesson today...
yeah.. its annoying when you dont know how much gas u have..
Old Apr 9, 2005 | 01:09 AM
Dan66's Avatar
Dan66
If you've never done it (and assuming it's your problem), replacing the sending unit is really easy.
Old Apr 9, 2005 | 07:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
Sounds like it's time for either a new gauge or a new sending unit.
Old Apr 10, 2005 | 11:03 PM
1MeanMach's Avatar
1MeanMach
agreed...
maybe this week
Old Apr 11, 2005 | 09:46 AM
horseshoeing's Avatar
horseshoeing
Maybe you should look at replacing your tank too.
I had some car that would do that to you. It really sucks if you go on a long trip and got to stop all the time.
Old Apr 12, 2005 | 09:17 PM
1MeanMach's Avatar
1MeanMach
The tank is still relatively new. My only concern is that I will be taking my car to school, so I'll be making a few road trips back and forth (5 1/2 hrs) while I'm checking it out. I definately don't wanna be stopping every hour just to refuel [:'(]
Old May 18, 2005 | 12:27 PM
73Cleveland's Avatar
73Cleveland
A quick and easy test to see if it's the guage or sending unit is to pull the plug from the tank sending unit.
You will need someone in the car with the ignition on and watching the fuel guage. Get under the car and short the + lead from the sending unit plug to the frame. If the dash guage goes all the way to full then you know the sending unit is bad. If the guage doesn't move, you are in need of a new dash guage and/or wireing.
You should also check the electrical plug to sending unit connection to make sure it is clean and the ground is good.
Been there & done that!
Old May 18, 2005 | 02:43 PM
68FastbackGT's Avatar
68FastbackGT
ORIGINAL: 73Cleveland
The wiring in my 68 use to do this test all by itself. The insulation around the wire had determinate and the bare wire would ground out on the frame when I hit a bump. I considered it to be a automated self diagnostic.
Old May 18, 2005 | 03:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
Mine only registers 3/4 full after I have filled it to the brim. I just figure when it gets to 1/4 I need to start looking for a gas station. This is just one of the quirks of these old dinosaurs. At least it registers something.
