Aod Ecore trans?
Old Mar 20, 2008 | 02:56 PM
theAutomatics's Avatar
theAutomatics
Default Aod Ecore trans?
Whats the difference between an Aod and AodE core transmission?
Old Mar 20, 2008 | 03:04 PM
urban_cowboy's Avatar
urban_cowboy
Default RE: Aod Ecore trans?
AODe is the first of the electronic overdrive trannys. The orginal AOD was all hydraulic with a TV cable.
Old Mar 20, 2008 | 03:47 PM
theAutomatics
I've always heard to stay away from Aod's. Should/can aode's be beefed up for a 450hp application?
Old Mar 20, 2008 | 05:36 PM
deadcarnahans's Avatar
deadcarnahans
Go one step further. The 4R70W is a much improved version of the AODE.
AODEs are much more scarce anyway. In Mustangs they were only offered in 1994 and 1995
96 up 3.8 liter cars had the 4R70Ws that will bolt to a Windsor.
Read the tranny tech article at www.tccoa.com
Old Mar 20, 2008 | 11:41 PM
LCC's Avatar
LCC
Stock is just that, stock. Now the question was can you beef up an AODe, yes. Why spend the money on an AODe and not an AOD? I'll never understand the myth that an AOD will not handle power. A stock AOD is rated at 450 HP, changing the input shaft and adjusting the TV cable properly and you can get lots of life out of oneover 450HP.Mine has stood up to all my abuse and still going strong.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
97SN95GT
Sep 13, 2015 09:45 PM
