Engine Starts and Stalls
What type of carb do you have? Check to see that when you are first starting it up cold, your choke plate (butterfly) is almost closed.. When she warms up your choke should pull the plate open.. Different carbs are adjusted differently..
ORIGINAL: REAVER117
I've been cleaning up my engine, trying to get 15 years of dirt and oil off, and now when I start the car it starts up right away, but then stalls if I lift my foot off the gas. As long as I keep pressure on the throttle the engine runs fine, but as soon as I let it idle the engine just stalls. All I've done to the engine is clean everything up as well as hook up the vacuum advance/retard which had previously been disconnected. Do I just need to adjust the Curb Idle or could this be a timing issue? Ideas?
jpplaw
Mar 19, 2025 08:53 AM
bryan616fl
Jan 25, 2019 09:07 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
