4 jack stands - ok to do with engine still in?
Old 03-21-2008, 02:17 PM
pwrl3ss
pwrl3ss's Avatar
Default 4 jack stands - ok to do with engine still in?
I know it might be a stupid question, but I'm just trying to play it safe. I know I can have the rear jack stands on the front part of the rear frame, but for the front, is it relatively safe to have the other pair of stands on that bar under the oilpan? Or is there a safer spot? The labels on the jack stands warn only to use 1 pair at a time.
Once it's up on the stands, is it ok to get inside the interior?
Thanks
pwrl3ss is offline
Old 03-21-2008, 02:37 PM
JamesW
Moderator
JamesW's Avatar
Default RE: 4 jack stands - ok to do with engine still in?
If the rear end is still installed, I have two stands under the rear axle out by the springs and two stands under the front frame rails, just before they raise up to the fender apron. Plenty safe to get in
JamesW is offline
Old 03-21-2008, 03:03 PM
jlg2002
jlg2002's Avatar
I typically put the rear stands where James does and the front stands under the Lower control arm or anywhere on the frame, from the front cross bar to the body. The key is to use quality jackstands, not the flimsy ones that only cost a few bucks so that the car doesn't wiggle around while on the stands. You also want to go as wide as possible with your jackstand placementin the cars' footprint so the car is stable.
jlg2002 is offline
Old 03-21-2008, 03:14 PM
jspagna1
jspagna1's Avatar
ORIGINAL: JamesW
+1
jspagna1 is offline
Old 03-21-2008, 05:35 PM
baddog671
baddog671's Avatar
I usually have my jack stands under the subframe connectors since they are solid, but besides that I will use them under the differential and as far forward on the frame rails as possible.
I usually have my floor jack still under the car but not supporting any weight. That way, should the car come down, the jack should atleast hold it for long enough for me to get the hell out.
baddog671 is offline
Old 03-21-2008, 07:16 PM
ThanksDad
ThanksDad's Avatar
When my Dad gave me my car it came with rolled steel jack stands from the 70's. They went to the dump fast. I got 4 brand new heavy duty stands each rated about twice the total weight of my whole car.
I also use the rear differential and the front frame rails. The bar under the oil pan will not support the weight.
ThanksDad is offline
Old 03-21-2008, 09:07 PM
baddog671
baddog671's Avatar
The bar under the oil pan WILL support the weight, assuming you are talking about the cross member and not the centerlink of the steering. That's what I use all the time to jack the front of the car up..
Old 03-21-2008, 09:25 PM
67mustang302
67mustang302's Avatar
ORIGINAL: JamesW
That's how I do it as well.
67mustang302 is offline
mtgldr
02-03-2024 09:00 PM
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
uedlose
09-10-2015 03:30 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: 4 jack stands - ok to do with engine still in?
