need scoop help!
Old Apr 10, 2005 | 10:47 PM
mach12004's Avatar
mach12004
Default need scoop help!
Hi,
I have almost finished the chassis and I am getting ready for paint. I have one problem. Years ago someone replaced both quarter panels but failed to place the scoops in. So I have a 69 Mach 1 which looks like a 70 from the side.
I bought scoops and the receptacles for the scoops--These were cut out of a wrecked car. I need the dimensions/ template to properly cut out my quarter panels and weld in the receptacle. If anyone has suggestions or measurements/template I would appreciate it. Thanks in advance. HSB
Old Apr 11, 2005 | 06:53 PM
69mach1377's Avatar
69mach1377
Default RE: need scoop help!
Create a template made of cardboard...cut out by trial and error.
Old Apr 11, 2005 | 08:31 PM
mach12004's Avatar
mach12004
I just wanted dimensions relative to the front edge of the quarter and where the cutout sits in relation to the body lines of the quarter. My car is also meadow lark yellow like yours(69mach1377).
Old Apr 12, 2005 | 02:08 PM
69mach1377's Avatar
69mach1377
The contour line of the front edge of the scoop is 1-3/8" back from the edge of the quarter panel. The actual cutout is a little bit more of course.
Hope that helps...
My car's color is supposed to be grabber yellow (1971) or yellow (1970), the photo may show up as the lighter color you mentioned.
Old Apr 12, 2005 | 05:48 PM
mach12004's Avatar
mach12004
Thanks for the info. HSB
Old Apr 12, 2005 | 07:46 PM
dodgestang's Avatar
dodgestang
leave it be, slap some boss 302 badges/graphics on it. They came with the scoops deleted anyway.
Old Apr 12, 2005 | 08:21 PM
69mach1377's Avatar
69mach1377
If your body code is truly 63C, and you want it to be correct, ignore that last comment. He must has scoop envy...
P51_GT
ROUSH Performance
24
Apr 6, 2019 09:19 PM
PaulH2
20
Jan 31, 2016 09:48 AM
GentleBen
Sep 11, 2015 05:34 AM
kdryan
Aug 21, 2015 04:01 PM
MustangHead91
Aug 16, 2015 03:20 PM
