front end rebuild question
Old Mar 28, 2008 | 11:33 AM
racin66coupe's Avatar
racin66coupe
Default RE: front end rebuild question
ORIGINAL: Starfury
Control arms are the same (I checked on my comp here at Napa, if you're doubtful). Tie rod ends are different. I try not to put Autozone through the motions...they get lost a lot:P
i try not to as well, they got confused when i was asking about axels formy honda[&:]
napa seems really intelegent though.
so, i think ill just leave the control arms alone and just replace the ball joints as well as sway bar etc
Old Mar 28, 2008 | 11:37 AM
racin66coupe
hey starfury, could you check the prices on the ball joints and tie rod ends at napa?
thanks
Old Mar 28, 2008 | 11:40 AM
racin66coupe
it also looks like the steering linkage is different, looking at rebuild kits. is this true? i just dont want to spend money i dont have to
Old Mar 28, 2008 | 11:50 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Sounds like you need a list of stuff you need to change so here goes. Sway bar, spindles, inner and out tie rods.idler arm, center lik, hubs and brakes, upper and lower ball joints, springs. That will do your front suspension and front brakes. If you are talking about piecing it together from NAPA you better off just shopping for a good kit on line. Cheaper in the long run.
Old Mar 28, 2008 | 12:13 PM
racin66coupe
67, yeah, i plan on getting the steering rebuild kit from opentracker, i have the spindles, getting the kh kit from csrp, 620 drops kyb gas adjusts, ball joints,some 1 1/8 sway mar most likely, maybe just a 1", that sound like everything?
Old Mar 28, 2008 | 12:21 PM
dcohen's Avatar
dcohen
the steering stuff i think are the same for both models.
the steering stuff is different between i6 and v8 cars
Old Mar 28, 2008 | 01:52 PM
Starfury's Avatar
Starfury
In your situation, I'd just replace the UCA's. Ball joints are like $30 a side (from Napa), but I think you can get full UCA's from a Mustang supplier for like $65. That way you get a freshbushing in there, because who knows what condition the original is in. Good time to do the Shelby drop as well.
I'm showing outer tie rod ends as $45, part # 269-2150.
svastano
25
Jul 16, 2016 01:20 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Tyoung68
Aug 25, 2015 04:31 AM
mikecaputo
Aug 22, 2015 10:58 AM
Mnuckolls
Aug 9, 2015 08:54 AM
