New Leaf Spring. Got luckie!!
Old Mar 28, 2008 | 06:53 AM
UBY289's Avatar
UBY289
Default New Leaf Spring. Got luckie!!
Well I amfinishing up with the new leaf spring installation. I really lucked out when I remove the old springs. It only took me a couple hours to get the old ones out. No problem with the eye bolts it just pulled right out. There are pics of what the bolts and shackles look like after years of a car beingfrom California.
[IMG]local://upfiles/32123/52EB862F3CBD4EE791AC6081B82C8E23.jpg[/IMG]
[IMG]local://upfiles/32123/342DAF2580154E369B3BF9916D646D1D.jpg[/IMG]
[IMG]local://upfiles/32123/00A7B41D3D754701A8D9FF023CE4ABFF.jpg[/IMG]
Old Mar 28, 2008 | 07:18 AM
03Maverik's Avatar
03Maverik
Default RE: New Leaf Spring. Got luckie!!
I just took mine off last night, too. All was good, except for one bolt that needed the influence of a grinder. What kind of springs are you putting back in?
Old Mar 28, 2008 | 09:47 AM
cprstreetmachines's Avatar
cprstreetmachines
You got really lucky, I had one customers car that I had to torch out the whole leaf spring eye to get it out - luckily the stock spings were coming out too
It was a 70 mach 1 that was purchased off ebay out of state.
Old Mar 28, 2008 | 10:00 AM
UBY289's Avatar
UBY289
I am just putting a standard stock leaf back. It maybe a little stiff than stock.The old ones where of bad that I couldn't take people in the back seat.You can see by the pic how much it was saging on the driver side , this was even after I installed new shocks.
[IMG]local://upfiles/32123/E5B349801D6D4EA2B76B16F085A2ADD5.jpg[/IMG]
Old Mar 28, 2008 | 10:26 AM
boogerschnot's Avatar
boogerschnot
You know.. Mine still sits a little lower on the drivers side even after new springs.. I think I may have some frame issues.. or shackle mount problem. I was lucky too, my bolts slid right out,, the bushings on the shackles were the hard thing to coax out..
Old Mar 28, 2008 | 01:33 PM
baddog671's Avatar
baddog671
Aww, you missed all the fun! Stuggling with that one bolt all day is the joy in working on the rear springs.....pff, yea right
Good to see it worked well for you. I had to put a 7.5" cutting wheel on my 5" grinder...scary!
Old Mar 28, 2008 | 01:40 PM
UBY289's Avatar
UBY289
I know . I heard alot of horror stories about the dreaded eye bolts.
Old Mar 28, 2008 | 05:39 PM
rdraper's Avatar
rdraper
I had to cut the nut, and the end of the bolt off. And still could not get it out. I didn't have a torch so drilled out the head of the bolt to get my stubborn leaf spring out.
here is a picture of the head of the bolt. It is not a nut. I kept it in the garage as a conversational piece. I was a little off center. But not bad for where this bolt was.
Old Mar 29, 2008 | 11:34 AM
UBY289's Avatar
UBY289
Doesn't sound like you had it easy at all . I can't wait to see what my car will sit like. I measured the height from the ground to lip of the fender center of the wheel well. It was 23 1/8 on driver side and 23 3/4 on the other . It will be interesting to measure when its done .Not sure on working on it today the temp here is 30 F and tomorrow 15 F.
drfister
May 3, 2018 10:38 PM
Glocker23
Sep 23, 2015 08:19 AM
Sep 16, 2015 07:53 PM
AMWill
AmericanMuscle.com
26
Sep 8, 2015 01:32 PM
steelers743
Aug 31, 2015 07:16 AM
