351 w piston
Old Apr 2, 2008 | 10:21 PM
onegreedy's Avatar
onegreedy
Default 351 w piston
i opened up the 351 trying to see what i am looking at,
everything inside looks brand new except the tops of the pistons(carbon build up)
down side looks like allready bored 40 over, and the weird thing is i have never seen a piston shaped like this see pic
is this a standard cutout for a 351 piston?
see how shiney new the side looks, like it just came out of casting is this normal for a 5000 mile motor?
Old Apr 2, 2008 | 10:34 PM
BigIron22's Avatar
BigIron22
Default RE: 351 w piston
that looks like the top of the pistons that came with my 351w out of a 84 f250. i replaced them with flat top pistons.
Old Apr 2, 2008 | 10:45 PM
mustanglover66's Avatar
mustanglover66
Those are dished pistons used to lower compression. The sides should stay shinney for the whole life of the motor.
Old Apr 2, 2008 | 11:07 PM
onegreedy's Avatar
onegreedy
but basically low compression naturally aspirated means loss in power correct? versus if i have just notched or flat top pistons,
Old Apr 2, 2008 | 11:35 PM
racin66coupe's Avatar
racin66coupe
yes
Old Apr 2, 2008 | 11:41 PM
67mustang302's Avatar
67mustang302
Higher compression can make more power from better thermal efficiency, you can also run a larger cam. You need to have an engine that'll run with the fuel you have available though. Many of the newer n/a EFI engines are running 10.0-11.0:1, some as high as 11.5....but I'm sure the knock sensor triggers frequently at low rpm.
Old Apr 3, 2008 | 01:15 PM
onegreedy's Avatar
onegreedy
i will probobally get some flat 9.6-1 pistons these are a 7.6-1 cr
Old Apr 3, 2008 | 02:53 PM
67mustang302
7.6:1 is great compresion......for running 18psi of boost on pump fuel.[&:]
Old Apr 3, 2008 | 03:57 PM
JMD's Avatar
JMD
You must consider the heads you are going to run in conjunction with your pistons.
We are running dished pistons (-15cc) with 60cc chamber heads on the 408 to come up with a little more than 11 to 1 CR..
Head gasket thickness and piston deck heightare CR factors as well,,,, these will both tend to lower it a little..
poke68
Dec 16, 2025 03:36 PM
uberstang1
Dec 7, 2017 07:10 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
degner122
Sep 16, 2015 07:09 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
