Engine code
yoou get this information from the block casting number (under starter).
But the K-codes didn't use K-code blocks, so to identify those you'll have to check on your heads (remove valve cover)
Kalli
Kalli
actually I'm wrong. you won't find info on A or C code on the block either if i'm correct.
You can idenmtify the block (here's a list)
http://raceabilene.com/kelly/hotrod/engine2.html
and here's info on where to find the casting number
http://www.aacncclub.com/FORD_BLOCK_...l#302fordblock
but the difference between A code and C code is more or less only 4V intake and 2V intake. maybe different compressions as well.
Sorry for the misinformation
casting will tell you what block. But it won't tell you if it's an A,C or K code
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
