Engine code
Old Apr 3, 2008 | 04:58 PM
fast65's Avatar
fast65
Default Engine code
This may sound like a stupid question but...Where is the engine code on the block? I found one, but I'm not sure if it's the one I'm looking for. Thanks in advance.
here's where I found the code
Click Here
heres the code itself
Code
BTW, please excuse the dirty engine.[8D]
Old Apr 3, 2008 | 05:04 PM
Passing Time's Avatar
Passing Time
Default RE: Engine code
Looks like a date code.
If its a 65 block you should find casting e.g. C5AE and a date code behind the starter (you will need to drop the starter to see it)
Old Apr 3, 2008 | 05:05 PM
Passing Time
If that's a date code I believe that means DEC 16 1969.
Old Apr 3, 2008 | 05:17 PM
fast65's Avatar
fast65
So what does the "M" mean.
Old Apr 3, 2008 | 05:27 PM
silverblue66's Avatar
silverblue66
Where is the "M" and are you sure its not a "W" if t is a W it may be the foundry mark. I am remembering this from an old casting Number bok. but I think a W is windsor foundry and a Cl is Cleavland. ignore the fact that its a windsor engine, both foundries made both widsor and clavland engines. for example I have a 64 289 Wndsor from the cleavland foundry. This cold all be wrong its from memory. Hope it helps.
Kip
Old Apr 3, 2008 | 05:30 PM
kalli's Avatar
kalli
m= december. here's the list:
A = Jan
B = Feb
C = Mar
D = April
E = May
F = June
G = July
H = Aug
J = Sept
K = Oct
L = Nov
M = Dec
(there's no I)
for the engine code itself you'll have to pull the starter
more info in the FAQ
Old Apr 3, 2008 | 05:31 PM
silverblue66
oops. sorry I didn't see the links. thats part of the date code. I think its the month? a=jan b=feb...M=dec Dec isn't the 13h month. idk?
Old Apr 3, 2008 | 05:34 PM
silverblue66
I looked it up. dec is M becasue they didn't use I because it looks like 1.
Old Apr 3, 2008 | 05:39 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Second Digit
Month
A
January
B
February
C
March
D
April
E
May
F
June
G
July
H
August
I
Not Used
J
September
K
October
L
November
M
December
9M16
= 16 Dec
but the 9 could be 69, 79, 89?
the casting number behind the starter will look something like C('60s) or D ('70s) then a digit for the year within that decade (5, 6, 7 or whatever) then AE which means A - Ford, E - engine.
if it has something other than A, it can be for a specific line. B - Bronco, Z - Mustang (examples - and there are lots)
try this...it takes a while to get your head around
http://www.classicmustang.com/decoding_part_numbers.htm
Old Apr 3, 2008 | 05:40 PM
fast65's Avatar
fast65
Thanks so much guys. One more questions. Where's the code on the block that will tell me what engine it is (i.e. A-code, K-code, C-code, etc...)? BTW, it's not the factory engine.
