Scary problem 3 days after getting the car back... (pictures)
RE: Scary problem 3 days after getting the car back...
ORIGINAL: _Remi
Any advice for the break-in?
As far as ring seating, do a couple 3/4 throttle runs through the gears Just try to keep the rpm's from climbing too high before you shift.
i had the same exact thing happen to my PS. my hose blew and fluid sprayed everywhere. even the headers. which means los of smoke. i know on mine i just cut the PS belt cause theres two belts, one for the crank, WP, alt. then the other for the crank, WP, PS.
so cuting the belt will be fine cause theres another one to back it up.
I had a similar experience that left my street covered in oil. At first I thought it was power steering, but then decided there was too much oil on the street, and I have heard that power steering fluid looks different. Then, I thought it might be the oil pressure sending unit (you might check that), but finally I figured out that it was just the oil filter. When I got the car I changed the oil and filter right away (literally the first work I have ever done on a car), and in the process the gasket from the old filter was left on there without me noticing, so the new filter was installed over that gasket. Surprisingly it lasted a few months that way, but finally gave out. You might want to check that too.
Unless you have A/C (which you don't), the pump shouldn't be hooked up to anything but the crank. Go ahead and loosen the pump, then remove the belt
Btw, I like the engine, looks really clean!
Earlier you stated that your PS pump has run dry.
Have you thought of maybe adding some more fluid to ascertain exactly where the leak is coming from?
New, replacement hoses are usually available locally.
Dave
Dave
Getting it to the shop without power assist
in the steering, will not damage the rack and pinion.
Running the pump without fluid though will damage the pump.
Dave
Location: Detroit; where the weak are killed and eaten.
wow that engine does look pretty though. idve panted that compartment while the engine was out. no advice from me that hasnt already been said, but thought id tell u ur engne sho does look purty
