DARN milky oil!
Old Apr 5, 2008 | 06:18 PM
bighairjer's Avatar
bighairjer
Default DARN milky oil!
Hello brothers I am looking for some help. I recently did a I6 to v8 swap on my 66 mustang. The donorengine was a nice running 68 J code. Got it running and took it to have the exhaust done and on the way back the valve cover was blowing quite a bit of whiteish smoke. When I got the motor I swapped in a new cam and intake.This was my first time dealing with ford engines, so I think I might have overabused the sealant on the intake gasket water ports during assembly.
At any rate, I pulled the intake today and it seems one of the gaskets was slightly moved during assembly. I dont know if that could be enough to cause water in the oil, but I am looking for advice. In another thread someone mentioned a cracked timing cover causing water into the oil.
Keep in mind there was no white smoke coming out of the tailpipe so I am semi ruling out a blown head gasket.
Any thoughts?
Old Apr 5, 2008 | 08:58 PM
wrenchturner75's Avatar
wrenchturner75
Default RE: DARN milky oil!
a slightly shifted gasket could cause an internal water leak. i have a trick when installing intakes i got 4 old intake bolts and cut the heads off then ground a slot in the top of em. screw the studs in then lay in your gaskets and set the intake down this will flat out eliminate any gasket movement. then simply start a couple intake bolts then take a regular screwdriver an unscrew the studs! works perfectly every time
Old Apr 5, 2008 | 09:08 PM
bighairjer's Avatar
bighairjer
Thats a great idea about intake bolts. Thanks!
mungodrums
Sep 29, 2015 09:18 PM
wraith777
Sep 28, 2015 10:49 AM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
Sep 16, 2015 03:07 PM
