got a good autolite!
Old Apr 7, 2008 | 12:28 AM
flyingfool's Avatar
flyingfool
Default got a good autolite!
gotmyself anA code 4100 the otherday 53,00 original miles..so yay for me i guess. gotta rebuild it now haha
Old Apr 7, 2008 | 12:46 AM
Starfury's Avatar
Starfury
Default RE: got a good autolite!
Cool Don't worry, rebuilding 4100's is cake. Just don't lose the little ball bearing
Old Apr 7, 2008 | 03:27 AM
kalli's Avatar
kalli
got an autolite 2100. great carb. if the 4100 is as good a 4barrell as mine is a 2barrell, then you'll enjoy your buy ;-)
Old Apr 7, 2008 | 08:38 AM
TexasAxMan's Avatar
TexasAxMan
I got an extra ball bearing in my kit. Make sure you put it in the right hole.
Old Apr 7, 2008 | 12:27 PM
kalli's Avatar
kalli
sorry about my ognorance here. but where does a carb need a ball bearing? throttle plate axis?
Old Apr 7, 2008 | 04:49 PM
TexasAxMan's Avatar
TexasAxMan
It functions like a check ball. Most people call it a ball bearing cause that's what it looks like.
Old Apr 7, 2008 | 09:42 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
There are two little ***** in a 4100. One is bigger than the other and comes in most kits. It's bigger than a BB. This ball goes under the primary venturi and is called the pump discharge ball check.
The smaller of the ***** is the one that's easy to lose. This ball is smaller than a BB. This ball does not come in most kits. In fact it may not even show up in the kit's exploded view. It's called the secondary vacuum passage ball check. It is located in the vacuum passage that ends at the top of the secondary diaphragm cover. When you take the secondary diaphragm cover off, stand the main bowl up and this little bugger should come rolling out. DON'T LOSE IT. Your secondaries won't work right if you do.
Buy a quality kit and a shop manual if you don't already have one. Read until you have a good idea of what's to be done and then have at it. If you're prepped and careful it's a walk in the park.
Old Apr 7, 2008 | 09:56 PM
racin66coupe's Avatar
racin66coupe
ORIGINAL: TexasAxMan
umm.... i hope your talking about the ball bearing lolz
Old Apr 8, 2008 | 12:53 PM
flyingfool's Avatar
flyingfool
^ yeah, right hole is always a good idea
thanks for all the tips, i havnt really even looked at the parts for this thing. wont be on fora little bit, have to get an intake, thinking wieand.....and a hot girl asked me to go on a road trip in a couple months..gotta save my mulah for that! good times
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
ctgreddy
Sep 20, 2015 08:35 PM
TfcCDR
Sep 12, 2015 04:13 PM
Sparks_88
Sep 8, 2015 01:06 PM
