crankshaft
Old Apr 9, 2008 | 08:53 PM
duke15's Avatar
duke15
Default crankshaft
i need a new crankshaft for my 1972 351 cleveland engine, a crankshaft for the street, that will really wake it up, any suggestions?
Old Apr 9, 2008 | 09:05 PM
tyler72's Avatar
tyler72
Default RE: crankshaft
To wake it up... a stroker kit, otherwise just chaging the crank wont net any power gains. It doesn't matter if you put a $1500 billet crank in it, it won't make any difference. You could put in a stroker kit and add a better cam and intake and you would notice a big improvement.
Old Apr 9, 2008 | 09:08 PM
duke15's Avatar
duke15
well ive already got a edelbrock rpm air gap intake,750 cfmthunder avs series carb, a performance carter fuel pump, high volume oil pump, and water pump, and im debating on whether to get a new cam or not
Old Apr 9, 2008 | 09:52 PM
racin66coupe's Avatar
racin66coupe
if you ask me, that 750cfm is hurting your power, not enough motor for it. at least its its just a 351c with a intake
Old Apr 9, 2008 | 11:34 PM
Aussie66Fastback's Avatar
Aussie66Fastback
duke are you getting crank and cam shaft mixed up maybe?
Old Apr 10, 2008 | 12:41 AM
67mustang302's Avatar
67mustang302
Camshaft or crankshaft?
As far as a crank, a superlight billet crank will cause the engine to make more power, a lot less rotating mass to move around(otherwise race cars wouldn't be using the lightest crank possible, they'd use a heavy crank that's stronger). That being said, it's overkill for most street engines. Scat, Eagle etc cast steel replacement cranks are good, cost the same as stock, but a bit stronger and a bit lighter. For a stroker I'd get forged, but it doesn't need to be some $5,000 Crower superlight race crank if it's a street engine.
bryan616fl
Jan 25, 2019 09:07 PM
S'PortMustang69
Aug 30, 2015 08:27 PM
Nichepi
Nov 17, 2005 02:36 AM
uedlose
Aug 21, 2005 05:58 PM
blue50lx
Aug 4, 2005 11:55 PM
