T5 in a 69 Mach1
Old Apr 16, 2005 | 10:11 PM
281GT's Avatar
281GT
Default T5 in a 69 Mach1
I have a question that I wanted to toss out there to see if anyone has any ideas. A friend of mine has a very nice '69 Mach 1. It has a 351W that had the old cast iron FMX 3 speed auto.. He swapped it for a T5 and is having problems with a clutch linkage. He found a pedal and arm setup but does not want to use the '69 type machanical linkage setup because they are hard to find and didn't really work all that well.
Problem is that there is no place on the firewall to bring the cable through that lines up with the link point of the clutch pedal.
I was thinking of a hydraulic clutch.
Does anyone out there have any ideas for a posible donor vehicle that might have a hydraulic clutch setup that might be adaptable for this?
Old Apr 17, 2005 | 12:09 AM
vfast's Avatar
vfast
I ♥ Acer
Default RE: T5 in a 69 Mach1
you should be able to drill a hole to fit..just make sure you use a gormet
Old Apr 17, 2005 | 03:37 AM
Soaring's Avatar
Soaring
I ♥ Acer
Google JMC Motorsports and McLeod for a hydraulic clutch kit.
steelers743
Aug 31, 2015 07:16 AM
NeoTokyo
Apr 23, 2005 01:15 AM
SoT_Vengeance
Apr 4, 2005 09:52 PM
yoshis99_cobra
20
Sep 23, 2004 04:23 PM
