Headers on a 289
i have a 69 with a 302, i bought Hooker Competition longtube headers. They bolted up and fit perfect. The only thing was the powersteering cylinder would just graze it occasionally so i put on the bracket that lowers the cylinder and now there is plenty of room. They are very economical, only $160 at summit.
i think im gonna do the same thing. long tubes and purple hornies...
so which headers bolt up without any problems on a 66 with p/s? also, do all headers come with exhaust gaskets?
not trying to rob the thread... sorry...
I went with a pair of Flowtech headers instead of hookers, or patriots etc. Honestly I like the sound of the long tubes beter. Anywho I have a 351 winsor, but it wasnt a big deal getting them on didnt need the bracket, was a b**** to get in that tight area though.
Almost the same ones I bought...
http://store.summitracing.com/partde...p;autoview=sku
I would agree with snorulz. I have a '68 and put Hooker Comps on it. Bolted up no problem even with the P/S. I think the long tubes give better performance than the tri-Y's. The longer tubes seem to equalize the back-pressure better than the shorty's or tri-Y's. That's just my opinion. They will also probably make for a more agressive sound, especially with the Purps. I would advise spending the money on some good header wrap ($60-100 from Summit/JEGs) or making a heat shield. It will save you the price in P/S hoses in the long run.
ORIGINAL: Montanas Mustang
on a street car operating at lower revs and over a range, tri-ys are suposed to give better scavenging for improved fuel economyand more bottom endtorque.
tri-y is a style not a brand. I had power steering and tri-ys in my 66 with no clearance issues. i have since ditched the p/s.
header wrap will kill the header. even wrapped stainless steel will eventually rust when wrapped. between the trapped in moisture and the trapped in heat the last set of headers i wrapped.(stainless on a motorcycle) rusted through in less than a year
ORIGINAL: 67mustang302
Long tubes like Hooker Super Competitions, the ones with the smaller primaries, 1 5/8" not the 1 3/4".
[/quote]
you would be better off putting the header wrap on the power steering hoses.
[/quote]
I understand what you are saying, but if the headers are in good shape, clean, and dry, when wrapped they should be OK. I have seen lots more unwrapped, rusty, nasty, problem causing headers than I have seen wrapped headers that failed. Everyone has their own preference but I think the benefits (lower engine compartment temp, less problems with hoses/lines/wiring next to the headers, and just better appearance) out weigh the problems. In a cramped engine compartment heat is always an issue and header wrap is an inexpesive solution to a lot of problems. I prefer the black ('cause it just looks cool!) to the white but to each his own.
[/quote]
ive got tri-ys the cheapys from npd i think they were 129$ ?? but they dont clear all the steering parts and i have ms they also didnt clear a 65 style top loader pushrod ive got to get the 66 style its adjustable
junior04
Sep 28, 2015 10:53 AM
