what else can I do to add more performance?
Old Apr 14, 2008 | 04:17 AM
javier146's Avatar
javier146
Default what else can I do to add more performance?
I currently have a c4, 351 with edelbrock top end kit, stock rear end. I am not looking for any type nitrous or superchargers either since it has hyper pistons. I was thinking of going with diff gears since I think this is the only thing left to do on my car. What type of gears should I get and how much is the price on new gears. I am a noob when it comes to gears by the way.
Old Apr 14, 2008 | 06:39 AM
baxsom's Avatar
baxsom
Default RE: what else can I do to add more performance?
that would depend on the gears it already had in it.
i was priced 600 bucks to install gears in mine.
Old Apr 14, 2008 | 07:21 AM
baddog671's Avatar
baddog671
Wow, 600 bucks is alot. You could get an entire used center with select gear already installed for less than that.
Old Apr 14, 2008 | 01:37 PM
javier146's Avatar
javier146
so what would be an acceptable price range for new gears in an 8inch rear end?
Old Apr 14, 2008 | 01:59 PM
maverick75's Avatar
maverick75
try a junkyard, bobcats and mustang II had 8"s with 3.55 gears and locker
a good set of 8" gears will run you about 150-200$
Old Apr 14, 2008 | 02:15 PM
TexasAxMan's Avatar
TexasAxMan
I've seen complete pumpkins, with limited slip and your choice of gears for $670-800 on eBay. This is for an 8".
I would think gears would be ~$150-200 and install about the same. Total of not more than $450.
Old Apr 14, 2008 | 02:26 PM
67mustang302's Avatar
67mustang302
Setting up gears PROPERLY is time consuming. That's why it's not cheap.
Old Apr 14, 2008 | 05:40 PM
ninteen66mustang's Avatar
ninteen66mustang
Do you have exhaust? what about a shift kit in the tranny?
Old Apr 14, 2008 | 06:01 PM
Aussie66Fastback's Avatar
Aussie66Fastback
+1 67m302
if you have the original 8" chances are most all of it is worn.
if you just throw some gears at it you'll prolly end up disappointed.
imo you should save up and do it properly
3.55 is a good choice to wake it up without destroying your wallet if you have to drive it on the highway anywhere and its good bang for buck performance increase.
Old Apr 14, 2008 | 09:44 PM
javier146's Avatar
javier146
Money is not a issue, plus my dad does the work himself-- The car is not going to be a highwaycar, so are these the best gears you can get?
