what else can I do to add more performance?
well you can go 4.11 or lower (higher numbers means lower ratio).
the higher the number the more acceleration you will get to a point but then it depends on your gearbox ratios as well.
so, for example, you might make say 40mph in first gear with your current rear gears at 2.78 or 3.00. If you change it to 4.11 it might only be 25mph in first but it will get there quicker. Theses are not actuals!!!
Speed at 5000rpm in top gear for a c4, based on 205/60/15 tyres - these are pretty close estimates.
2.78 - 132mph
3.00 - 122
3.55 - 103
4.11 - 89
4.56 - 80
its really your choice. 3.55 is a good compromise. 3.73 is popular with o/d trans and 4.11 up is normally drag racers who can and do pull waaaaaay more than 5000rpm.
if you never drive on the highway and you dont care about your gas bill then 3.73 or 4.11.
2.78 - 132mph
3.00 - 122
3.55 - 103
4.11 - 89
4.56 - 80
better which numbers?
a t5 or an AOD gives you an overdrive gear.
So, for example, if you have a 4.11 rear end. C4 in Drive is 1:1 so you get your 5000rev speed of around 90mph. With an overdrive, you get a final drive ratio (varying) ofaround 0.8:1.
So times the 4.11 by 0.8 and you have effectively a 3.3:1 ratio or say around 110mph at 5000.
it depends what you want the car to do. if its just blasting off the lights then beef up your c4, add a stall converter and change the gearing to anywhere between 3.5 -4.11. It will be cheaper than going to an overdrive trans and arguably stronger too.
I will probably go with the 3.55 and stall converter, If ever take the car to the track which gears will get me faster time, the faster launch gears or the 100 plus gears?
ORIGINAL: javier146
Would a t5 tranny swap help get better numbers than the c4?
Have you done any thing to improve the ignition?? A hot ignition can go a long way to improve the power of a engine
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
