cam journal lube
Old Apr 17, 2008 | 07:30 AM
baxsom's Avatar
baxsom
Default cam journal lube
what would be better for cam journals during install. the packet of lube supplied with the cam says for lobes and distributer gear only so thats out.
would the comp cams break in lube work better on the journals than the zddp packed motor oil
or does it really matter since its all going to get splashed with motor oil as soon as you prime the oil pump and then spin the engine anyway
Old Apr 17, 2008 | 07:46 AM
69thunder's Avatar
69thunder
Default RE: cam journal lube
No, use the lube very liberally. Use all of it. Oil alone on initial start up is NOT enough.
Old Apr 17, 2008 | 08:21 AM
baxsom's Avatar
baxsom
yeah thanks for the reply but that doesnt answer the question.
the lube supplied with the cam specifically says to use on lobes and gears,
the question is is motor oil or the comp cams break in lube part # cca-159 used to pour in crank cases better for the journals
Old Apr 17, 2008 | 08:45 AM
Starfury's Avatar
Starfury
Motor oil is fine for the journals, although I used moly assembly lube on mine. Theassembly lube sticks a little better than straight motor oil without being as thick as the cam lube.
Old Apr 17, 2008 | 08:53 AM
69FECoupe's Avatar
69FECoupe
I have been using this for well over thirtyfive years. Works great. I'm sure there are other quality assembly lubes out there but I am a creature of habit. http://www.permatex.com/products/aut...embly_Lube.htm
Old Apr 17, 2008 | 09:14 AM
69thunder's Avatar
69thunder
ORIGINAL: baxsom
Yeah, I did. Use the lube on everything to do with the cam. Journals, lobes, all of it. Then you don't need the break in lube. At least I didn't.I slathered the stuff that came with my cam on everything and it worked great.
Old Apr 17, 2008 | 07:48 PM
Starfury's Avatar
Starfury
You should not put cam break-in lube on the bearing journals. It's so thick and sticky that it can clog up the oil ports and prevent the bearings from getting enough oil. That's what moly assembly lube is for.
Old Apr 17, 2008 | 09:26 PM
tyler72's Avatar
tyler72
Molly is a sweet person. She keeps that high dollar engine from getting ruined during the first few seconds. lol. Go with moly lube on them.
Old Apr 18, 2008 | 10:21 AM
TexasAxMan's Avatar
TexasAxMan
Where can you get the cam lube? I have a cam that has never been run but no lube. Does the molybdenum (sp?) grease go by other names? Can you just buy moly grease? Inquiring minds want to know.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
