Engine Cowl paint
Old Apr 20, 2008 | 06:48 PM
p25486's Avatar
p25486
Default Engine Cowl paint
Hi, I was thinking of painting the inside, and possibly the out side of the engine cowl (air intake for the heater and such) with POR15. There's a little rust so I thought that might be a good idea to use the POR15.
However, the black POR15 is very shiny when dry. Do I need to top coat it with something less shiny, or will it really be noticable?
Or, should I use something else for this area and or detailing the engine area?
Thanks,
John F.
Old Apr 20, 2008 | 07:24 PM
retro77's Avatar
retro77
Default RE: Engine Cowl paint
I dont have a lot of experience in this but I would want it to match whatever the rest of your engine bay is.
Old Apr 20, 2008 | 07:38 PM
mustanglover66's Avatar
mustanglover66
POR15 is a type of primer you need to topcoat it.
Old Apr 20, 2008 | 11:33 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
por15 doesn't need to be top coated unless its exposed to direct sunlight where your using it
Old Apr 21, 2008 | 10:25 AM
zmetalmilitia's Avatar
zmetalmilitia
You can read up on the correct applications from distrubutors of POR15 on the web. That is another placce you should look to get additional info. google "POR15". There is a lot of good info on how to apply it, topcoat, etc. If that is what you want to use.
Nick Oliver
Oct 17, 2018 04:22 AM
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
mustangchef
Sep 4, 2015 08:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
