Exhaust pop
Old Apr 25, 2008 | 08:59 AM
69thunder's Avatar
69thunder
Default RE: Exhaust pop
Vacuum to the distributor should not have any at idle. If connected to the right port that is. It won't hurt anything if connected toa constant sourcehowever,as total timing stays the same, in fact one way to make large camshaft equipped engines idle a little better is to have the distributor vacuum hooked up to a constant source. All it does is advance the timing at idle which is not a problem. Definatly plug the hose when doing timing though.
Old Apr 25, 2008 | 09:58 AM
urban_cowboy's Avatar
urban_cowboy
Remove the vacuum if you have a vacuum dizzy advance dizzy. Your inital timing should be around 6* for a stock application, I think. Check your manual. You can always add more inital timing if you are not having detenation problems. After you get the inital timing set, reconnect the vacuum advance and check the total timing at around 3k. It should be in the mid 30s. If this is correct, your timing is set about right. If you do not get any timing advance at 3k or it is too high, you have a vacuum or dizzy issue.
Pops are sometimes a sign of running lean, vacuum leaks, and poor timing. I would get your timing lined out and check your vaccum lines and ports for leaks or unplugged unused ports. Once you get that lined out, do a test drive and see what you have.
Old Apr 25, 2008 | 01:26 PM
snorulz's Avatar
snorulz
Thanks everyone for the clarification. I had no idea my hose was wrong, i will have to switch it when i get the car out of storage. The logic makes sense now.
sorry ninteen66mustang about the bad info.
ORIGINAL: davesanborn
Your distributor will not have both a mechanical and vacuum advance.
Dave
I am confused on having either or when it comes to mechanical and vacuum advance. My accel 52201 dist. has both, this i do know for a fact.
Old Apr 25, 2008 | 01:37 PM
blue66mustang's Avatar
blue66mustang
The vacuum advance ONLY works a "tip in" and "cruising" throttle position !!.The purpose is to give the advance a little jump when you open thethrottle. This is then taken over by the mechanical advance as engine speed increases. So YES most distributors have BOTH.
Old Apr 25, 2008 | 03:43 PM
TexasAxMan's Avatar
TexasAxMan
I'm pretty sure that most distributors have both mechanical and vacuum advance.
Old Apr 25, 2008 | 04:02 PM
ninteen66mustang's Avatar
ninteen66mustang
Alright, thanks for all the info guys. When I get home from work ill check all the timing. On my balancer I only have one mark, which I am assuming is TDC. If I am standing in front of the car looking down at the mark, should it be to the right or the left of the thing coming off the block? for about 6* to 8* how far from the thing on the block should it be?
Old Apr 25, 2008 | 04:46 PM
blue66mustang
The timing will move the "0" mark farther towards the passenger side the MORE you move AWAY from TDC relative to the pointer.
Old Apr 25, 2008 | 05:54 PM
ninteen66mustang
okay thats what i thought, thanks.
Old Apr 25, 2008 | 07:47 PM
ninteen66mustang
ignore this thread, go to my new one:
https://mustangforums.com/m_4979856/...tm.htm#4979856
cr620
Oct 3, 2022 10:18 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Sep 30, 2015 12:39 PM
MacSerio
Sep 27, 2015 01:05 PM
Sep 24, 2015 09:18 PM
