Automatic shifter indicator
Old Apr 30, 2008 | 12:28 PM
Nabster's Avatar
Nabster
Default Automatic shifter indicator
I can find the little lamp assembly for an automatic shifter, but I can't find the actual little indicator piece anywhere. Somewhere in the life of our shifter, the little plastic(?) needle thing that lights up and shows you what gear you're in has broken off, and conveniently isn't to be found in the little area under the bezel to be glued back on. The lamp assembly is there but needs a new bulb, the black plate thing the needle sits on top of is there, and the bexel is there, but not the actual light-up needle. Does anyone know if they make that part to be replaced, or does anyone have one sitting around to sell? It's just for a standard 1969 3-speed auto.
Old Apr 30, 2008 | 03:28 PM
jlg2002's Avatar
jlg2002
Default RE: Automatic shifter indicator
have a look at pg 132 of the NPD catalog. I believe you're going to have to spring for a new bezel assy.
Old Apr 30, 2008 | 03:41 PM
Nabster's Avatar
Nabster
The Bezel assembly doesn't really have anything to do with it. That part I have and is fine, the little needle thing is under that and attaches directly on the shifter arm, it should stick out and rest on top of the black arched part.
[IMG]local://upfiles/43463/2CE005685C5140D69854B87AB014B5AD.jpg[/IMG]
Old May 7, 2008 | 02:46 PM
jlg2002's Avatar
jlg2002
Yeah, i see what you mean now. Try the ford store, cause it looks unobtainium from the normal sources.
Old May 7, 2008 | 03:11 PM
ThanksDad's Avatar
ThanksDad
Contact Cj Pony Parts. If they don't have it new thay may have it in thier Salvage Yard.
Old May 7, 2008 | 03:13 PM
ThanksDad's Avatar
ThanksDad
I don't know where you are but you or anyone you knows lives near Carlisle PA. the Ford Show is coming up next month. They have an incredicable amount of parts there.
jwog666
Dec 27, 2021 08:09 PM
firehorse02
Nov 16, 2015 11:28 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
