slave cylinder
Old Apr 30, 2008 | 02:38 PM
jimmy428's Avatar
jimmy428
Default slave cylinder
just found my p/s cylinder to be loose as hell. bushings are gone and the rod is bent at the end. should i get new bushings and unbend the rod or get a whole new piece?surprisingly it doesn't leak either.
Old Apr 30, 2008 | 03:10 PM
boogerschnot's Avatar
boogerschnot
Default RE: slave cylinder
If the rod is bent just buy a new cylinder.. It would be far better than trying to fix the old one and make it work.. Im supprised its not leaking. Is the rod scratched? Where at the end is it bent? If you could straighten it with a press and it not actually go into the ram bent then maybe you could get away with straightening it.
Old Apr 30, 2008 | 03:32 PM
jlg2002's Avatar
jlg2002
Exactly where is the rod bent? if at the end where the bushings go don't worry about it. If its in the chrome, time for a new cylinder.
Old Jul 21, 2008 | 09:08 PM
jimmy428's Avatar
jimmy428
i really am sorry for the lateness, I just have been going through some rough times and haven't had time to myself.it was bent at the end, not the chrome ram part. I straightenend it and it would've worked fine, but the threads were too damaged to save, so i just bought a new one the day after and installed it. it came in two days from virgina classic mustang. they are really good about their parts and delivery. works perfectly.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
