Carb replacement
Old May 5, 2008 | 03:48 PM
Convert66's Avatar
Convert66
Default Carb replacement
Hi, I just bought an Edelbrock 1405 (600cfm) for my '66 302 with stock intake. Old carb is ford 4300
I have a few questions :
1. Choke : Is it possible to install/fabricate a manual choke ?
2. Accelerator linkage : The installationmanual mentions a special ford linkage and a special plate. Is this really necessary, it seems to me that the acceleratorrod connects to the carb as is.
3. Are there any other problems I might encounter
Does anyone have any experience with this change-over?
Thx
"Experience is what you get, when you don't get what you want"
I hope not to get too much experience on this one. I'm working with a timelimit this time. It needs to be ready and reliable by next week.
Old May 5, 2008 | 08:09 PM
jfdfire2's Avatar
jfdfire2
Default RE: Carb replacement
I installed a 1406 with electric choke this winter so I'll answer to my experience,
1. No idea I bought an electric choke
2. The special kit is not needed for at least a 65 or 66 unless you have a newer transmission with a shift down cable.The accelerator rod will connect directly to the included carb linkage.
3. I had no problems with my install other than getting some dirt in the idle needles, which caused the carb to flood out.
The carb comes with good instructions and a great DVD to help with the install and any trouble shooting.
Good Luck
Old May 6, 2008 | 12:55 AM
Convert66's Avatar
Convert66
Thx, I'll get right to it then. Just need to figure out how to install a manual choke.
Old May 6, 2008 | 08:23 AM
deadcarnahans's Avatar
deadcarnahans
ORIGINAL: Convert66
It would be easier to just wire up the electic choke and let it do it's thing.
Old May 6, 2008 | 09:50 AM
kalli's Avatar
kalli
i'm not sure if the carb that you got has electronic or manual choke. Can you clarify that?
Old May 7, 2008 | 01:14 AM
Convert66's Avatar
Convert66
The 1405 only has a manual choke. I have to hook it by next week, so I don't have the time to order an electric choke. So for now I'll trie to install a wire to operate the manual choke.
I was just wondering if anyone has done this fora '66, no need te invent things twice.
Old May 7, 2008 | 04:29 PM
deadcarnahans
Holley carbs suck. But they do make a nice sturdy choke cable that will work with the EDL carb.
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
tramphardrocker
Sep 13, 2015 08:56 PM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
