Weight difference between manifold and headers?
Old May 5, 2008 | 07:56 PM
_Remi's Avatar
_Remi
Default Weight difference between manifold and headers?
Hi,
What would be the weight difference between stock exhaust manifold on a 1967 289 and a set of Hooker Super Competition long tubes?
Thanks for the information, I am still tracking some weight before I start working out
Old May 6, 2008 | 04:52 PM
ky's Avatar
ky
America ftw
Default RE: Weight difference between manifold and headers?
id guess that the stock manifold (1 of them) weighs about 6 or 7lbs. and a hedder weighs about 3-4 depending on what one. id say 4 for the hooker super comp. im just guessing but i assume a hedder weighs about 40-50% lighter.
Old May 6, 2008 | 05:20 PM
baddog671's Avatar
baddog671
Who cares, you're going to well compensate the few pounds...
Old May 6, 2008 | 05:38 PM
Norm Peterson's Avatar
Norm Peterson
I think it'll be close to a wash. 30" tubes x 4 (1-5/8" OD x 16 ga) is a little over 10 lbs just in the header individual tubes. Add a lb or so for the collector and its flange and a couple of lbs for the head face flange and each header side is 13 - 14 lbs. I'm thinking the iron manifolds are closer to 8 lbs apiece, and then you have to add 2 - 3 lbs for its head pipe to match up to the same place that the header would connect to. 13.5 (header) vs maybe 10 - 11 (manifold) per side? 5 lbs total?
Norm
Old May 6, 2008 | 09:05 PM
andrewmp6's Avatar
andrewmp6
Manifolds are cast iron and restricts exhaust flow.Headers flow a lot better and most are equal length tubes so they flow great.Only downside to headers is long tube ones can drag on speed bumps if your cars lowered.
Old May 6, 2008 | 11:56 PM
superdavid's Avatar
superdavid
ORIGINAL: baddog671
+1.
If you're going to start modding your car, it doesn't matter. Get 'em.
Whether you want speed, fuel economy, sound, whatever, headers are eventually going to be needed.
Old May 7, 2008 | 01:54 PM
_Remi's Avatar
_Remi
Thanks guy, I just received them
mtgldr
Feb 3, 2024 09:00 PM
Roxon68
Mar 17, 2016 08:13 PM
BrantleyS550
Sep 14, 2015 04:18 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 11:50 AM
